How important is it to resurface rotors after a brake pad change??
The subject says it all. I just changed out my pads and my good friend Bryan online told me that the rotors really needed to be resurfaced. I know that if the rotors are warped, etc. that the new pads will take that form.
I called my local Pep Boys and they wanted $36/side to take the rotors off and resurface. If I bring them in..its only $7/rotor. Problem is that my max is my only means of transportation.
How critical is it to resurface the rotors after a pad change??
well i was told this analogy
"its like taking a shower and not changing ur underwear"
now on a serious note, i wouldnt think its THAT critical but if u had some uneven spots in ur rotors than ur pads may wear unevenly. i always get mine re-surfaced when i get the brakes done.
Yes it is a good idea to have them surfaced. I have done probably a half dozen of my past cars without doing it....if they are not warped or grooved I can tell you you'll be fine. I always replaced pads before they damaged the rotors. For $7 if mine had shown wear or were warped I'd do it in a second.
Great tool Ben!
You should only resurface your rotors if they are pulsating, vibrating or show signs of glazing or scoring on the surface.
Don't take material off if it's not necessary, your only shortening the life of the rotor.
A quick scuff with some med grit emery paper will do just just fine when you put new pads on, but even that isn't really necessary if your rotors look and feel good.
Originally posted by njmaxseltd
Great tool Ben!
Great tool Ben!
what you need to do and what every brake pad manufacturer tells u to do is to break that glaze. rough it up a little so the new pads have something to bite on and can break in.
even if the rotor looks and feel good (how do u know how a rotor feels?
)...most of the time you'll need to do some kind of scuffing to break that shine.
Originally posted by mzmtg
http://www.braketru.com/
Both bring up good points. I used to always believe that you should always resurface your rotors, but last time I did not because I needed to get my car on the highway but nightfall and all the places were closed. I haven't seen any negative effects of this at all, but they were just resurfaced like 20K before the last change.
Anyways, the theory is that your pads and rotors sort of mesh together. The pad's imperfections create grooves and blemishes in the rotor. The pad and rotor fit well together and provide stopping performance via pad to rotor surface contact. By putting new pads on you have an unmated rotor with inconsistent grooves and a new pad that has it's imperfections. The two don't line up and mesh very well which means you have less stopping power because there is less physical contact due to the pieces not fitting together as well. Overtime they will mend to each other, but if you're rotors were really grooved from the old pads it could take forever.
I will probably resurface every other time from now on and I will resurface it as many times as I can before replacing the actual rotor. I would only buy higher quality pads, they make a difference in many ways, noise, dust, longevity, rotor wear, and braking performance.
Originally posted by MAXimumHP
Whats the deal with these things? Are they any good? Anyone know?
Back to the main topic, I've done many pads without turning the rotors. Technically you may wear the pads faster, but when they're lasting 65k a pop, wearing them faster is splitting hairs. If you got pulsation, by all means, you need to turn em.
Sorry it has taken me so long to get back with a reply, but this server is really hard to access. I can't believe the traffic this site gets!!
Anyway...I really appreciate all the responces. I have never experienced any pulsating, vibrating, or scoring from the rotors. I think I will try and scuff the rotors up a little to get the pads seated and broken in.
Thanks again,
Kevin
Thanks again,
Kevin
Re: How important is it to resurface rotors after a brake pad change??
Mar 12, 2020 12:06 AM
bbsitum
Sep 11, 2015 04:55 PM
