butterfly key
Old Feb 10, 2003 | 10:04 PM
BOZOnPJs's Avatar
butterfly key
i'd love one of these.. i'm looking to see if they make one for my 99. i didn't see one in the menu.
Old Feb 10, 2003 | 10:57 PM
RBa's Avatar
RBa
Re: butterfly key
Nope... You'd have to somehow disable the imobilizer chip. Cant start the car without one..
Old Feb 10, 2003 | 11:11 PM
95emeraldgxe's Avatar
i'd rather have the extra security than having a cool looking key, but if you must.........is it possible to swap out the ignition with an older one???
Old Feb 10, 2003 | 11:23 PM
RBa's Avatar
RBa
The imobilizer is built into the ECU. 99 and up..
Old Feb 11, 2003 | 05:53 AM
BOZOnPJs's Avatar
i don't have a chip on the side of my key though..
o well.
Old Feb 11, 2003 | 08:45 AM
PoLo's Avatar
2-Wheelin it...
o well.
Get a bypass module, i believe it's DEI part No. 555U.
put your chipped key in it hide it somewhere. wrap the wire-end of it around the key cylinder. have it power up with the ignition. now you're car is always coded. you can use any key (non-chipped) you want, because when you put the key in to turn on the car, the module will activate and the code will be picked up from your chipped key inside the box.
enjoy.
Old Feb 11, 2003 | 09:04 AM
enjoy.
whoa! - i never knew about that before - good read - thanks alot - how much does this module cost
Old Feb 11, 2003 | 09:14 AM
PoLo's Avatar
2-Wheelin it...
~$55 or less. PM Don aka Pearl96Max, he sells it
this isn't any special thing...it's what they use for chipped cars when they install remote starts. you activate remoe start, the signal is sent for a split second to the module, which sends the code to the cylinder. car turns on, and the module shuts off. if you turn on your car manually, then the module never activates because you are using your key. you don't want the ECU to read 2 codes. although the same code, you don't want it to start acting buggy. again, this is for cars that want remote starts and the security of a chipped key.
in your case, you want it to read the code everytime you turn on yoru car because you have a non-chipped key, so i would tap it to the starter or accessory wire (not sure, ask don) so that the module activated every time.
enjoy.
Old Feb 11, 2003 | 09:43 AM
1MAX2NV's Avatar
You might able to hack open the old key and extract the chip. Then you can implant the chip into your new key, but I have no idea where you can place it.
Old Feb 11, 2003 | 09:46 AM
Sprint's Avatar
you can also put the chip in the steering column.. but that defeats the whole purpose of the chip..
anywhoo.. just don't pull your keys on a Cop
Old Feb 11, 2003 | 10:04 AM
Romeo's Avatar
Old Feb 11, 2003 | 11:21 AM
MaxWolf's Avatar
I know someone that has these silver ones. I have a blue one myself, and I like it. I do not have a chip in my key so I didn't need to worry bout it. But as Sprint said, you can just put it in your steering column. Let me know if you want these keys. I can get ahold of 10 or so right now.
Old Feb 11, 2003 | 11:41 AM
Romeo's Avatar
price? and are they only for maxima's? i might need one for my S14
Old Feb 11, 2003 | 01:29 PM
BOZOnPJs's Avatar
they're 20 bux.. go to the web sight or ebay
Old Feb 11, 2003 | 01:44 PM
MaxWolf's Avatar
16.80 is what they cost him
Fbana41
Aug 29, 2016 12:18 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
maxinout93
Oct 16, 2015 02:53 AM
jerrod99_se-l
Sep 19, 2015 06:54 AM
