Photochoppers I need help.
Old Feb 24, 2003 | 07:16 PM
Redmax's Avatar
Redlinemax Owner
Can some one photoshop my center console in Red. I've been thinking of fiberglassing my center console and getting it painted the same color of my car. What do you think? I like the aluminum Dash kit, but i don't know how well it will match my car. I was thinking to maybe use this pic
Thanx in advance
Old Feb 24, 2003 | 08:05 PM
d_warner's Avatar
Old Timer
Re: Photochoppers I need help.
Thanx in advance
RedMax. Go ahead and post a pic of your car as well, so we can get the exterior color right. BTW, did you happen to see my painted dash at the January meet? If not, I got some pics of it. You may consider that as well.
David
Old Feb 24, 2003 | 08:29 PM
nadir_s's Avatar
vicodin ... gift of life
not sure the exact shade
http://nadir.sohounion.com/ps/red_dash.htm
Old Feb 24, 2003 | 10:04 PM
Redmax's Avatar
Redlinemax Owner
Thank you, click on my homepage to get a pic of the car please. I tried to attach a photo but they were all too large. Also can you make the color as glossy as the car I will send these to the paint shop to be shotif i like it. and I will keep the air vents black!! I just want the trim red. Thanks again!
Old Feb 24, 2003 | 10:23 PM
nadir_s's Avatar
k last pic, more red-ish like ure car
same link
Old Feb 24, 2003 | 11:24 PM
Redmax's Avatar
Redlinemax Owner
same link
Ahhh Thank You!!!!! What do you think ?
Old Feb 25, 2003 | 03:02 AM
metallic97gxe's Avatar
Master Will
try it man, it will be different you can always change it if you don't like it or get tired of it....
Old Feb 25, 2003 | 04:10 AM
Blu's Avatar
Blu
the tits
Old Feb 25, 2003 | 05:10 AM
lcf's Avatar
lcf
I like it.
Old Feb 25, 2003 | 06:46 AM
N34JZ's Avatar
Needs non-Maxima Friends
I dont think you have to fiber-glass it, the finish is pretty good already I had my gauge bezel painted the same time as my car and it looks just a smooth and shiny as the outside. and they didnt do any prep-work to it.
Old Feb 25, 2003 | 08:28 AM
thebigsadler's Avatar
i wouldnt recommend painting the dash itself unless you plan on sanding, sanding, sanding and sanding it down and then primering it and using lots of light coats of paint.. if you have someone or you know how to fiberglass that will be the better way to go because you have a smaller chance of it scratching and fading especially.
if you want to see something go to www.teameci.com and go to the members section, look for a blue celica and he has a full painted dash and then look for a green eclipse, his is all fiberglass.. its a huge difference in person, pictures may not look it, but trust me, you know which one was done right (eclipse).
Old Feb 25, 2003 | 11:51 AM
N34JZ's Avatar
Unless he means the dash and not just the console I think it would be fine with-out glass, isnt it smooth in 4th gens? My body shop told me when they do mine there just going to scuff the flat pieces ( switch plates , gauge bezel etc..) and then prime them and paint them as they would a car, he said the pieces with the grain or pattern on them they would probably just block out and bondo it smooth then paint. he said with a good base and clear it would resist scratching fine.
Taino14
Sep 24, 2015 02:51 PM
hozay99
Sep 19, 2015 10:20 PM
pears
Sep 18, 2015 05:25 AM
