No traction in 1st gear under heavy acceleration lately
Old Feb 25, 2003 | 03:08 PM
2KxSEx's Avatar
Hey,
I've noticed that my car doesn't have the traction it used to have under heavy acceleration anymore. Before I couln't even brake the tires loose in 1st gear from a roll. But now, it happens every time I get on it in 1st gear. Plus, I've gotten a lot more wheel hop lately. My tires are still in good condition, but I don't know if they're going to last much longer under these conditions . I really didn't change much in the car to justify the loss of traction. I did remove the maxspeed springs and left the GR2s in there. My camber should be back to spec now that the car isn't lowered. So more than likely that's not the problem. Maybe it's the cold weather here in NJ.
Let me know what you guys think.
Thanks.
Old Feb 25, 2003 | 03:13 PM
pjalst
you could be getting less traction because of all the sand and salt that's on the roads.
Old Feb 25, 2003 | 03:19 PM
2KxSEx's Avatar
You know what, I never thought of that. But all that rain we had this past weekend should have washed most of that away.
Peace.
Old Feb 25, 2003 | 06:33 PM
ch13f's Avatar
When it's really cold out, traction tends to suffer.. not to mention cold air = better performance out of your engine.
Old Feb 25, 2003 | 07:42 PM
GuZo's Avatar
I have the same problem in my 2k2, like it has been said before, it's most likely a mixture of the leftover salt on the roads and alot of power down to the wheel, gotta love the MAX.
Old Feb 25, 2003 | 09:55 PM
I30tMikeD's Avatar
Like stated earlier, the cold hurts traction and helps performance. In this 10 degreee weather in Chicago I can break the tires loose big time on my 1-2 shift.
Also my wheel hop seems to be much worse with really cold temps. I have a thread in the 1/4 forum concerning that.
Old Feb 25, 2003 | 11:25 PM
InfinitiStyle's Avatar
the cold weather makes the ground cold... Traction = Friction = HEAT. None on the ground.
Old Feb 26, 2003 | 01:08 AM
Nismo's Avatar
now wouldnt there be less friction if there was more traction?
Old Feb 26, 2003 | 03:07 AM
Y2K2Driver's Avatar
friction = traction
Old Feb 26, 2003 | 04:04 AM
wdave's Avatar
Cold makes the rubber harder, less traction. All season tires have compounds that work to lower temps than summer tires, but there's still a difference. Also, as tires age the rubber tends to harden - tread depth can be fine but the rubber can be dead.
Old Feb 26, 2003 | 04:50 AM
PCGuRu2K's Avatar
Re: No traction in 1st gear under heavy acceleration lately
Originally posted by 2KxSEx
Hey,
Thanks.
Maybe it's time to get a quaife
Old Feb 26, 2003 | 03:07 PM
2KxSEx's Avatar
Hey all,
Just killed two birds w/one stone The problem was in my front sway bar. When I did my suspension I left the front sway bar disconnected to get more oversteer. Well, I found out that that's what caused me to have less traction and made the ride harsher/gave me a lot of bump steer. Now that I tightened it, it's a whole different ball game. I've got the idea of the disconnected FSB in the autox forum. It seemed to make the car more neutral in hard turns, but not enought to justify the added body lean, bumpsteer, less traction, more harshness. So now I have my traction back. Before, when I went into a turn and got on it I would spin my inside tire, which never happened before I messed w/the FSB. I'm a happy camper I guess everything has a reason for being the way it is huh?
Thanks for all the input fellas.
Old Feb 26, 2003 | 03:57 PM
Mr.95GXE's Avatar
I have always had problems with traction in my '95 GXE 5spd. From a roll or a stop. I can get up to about 3,500 in first(rolling) then stomp it and I will get a good amount of wheel spin and a nice scratch in second gear. Car is stock and is still a good runner.
Old Feb 26, 2003 | 04:06 PM
2KxSEx's Avatar
I think the 95's have the most power and are the lightest. Enjoy your ride .
Peace.
Old Feb 26, 2003 | 06:18 PM
Lime's Avatar
by like 50 lbs on the 97-98
Old Feb 26, 2003 | 07:39 PM
2KxSEx's Avatar
Erica,
Thank you for confirming my statement.
Old Feb 26, 2003 | 07:52 PM
multiplexor's Avatar
yeah... mine was doing the same... but only really happens on super cold days...
which leads to less traction...
Old Feb 27, 2003 | 12:56 AM
Mr.95GXE's Avatar
My '95 will do it at any time of the year.
Old Feb 27, 2003 | 07:45 AM
bigdo26's Avatar
I have major traction issues with my 2k2 here in CT. between the coldness and all the sand and salt on the roads, my tires light up all the time. i hate doin it too... worst one was a week or so ago when i had to make a turn and this idiot almost sideswiped me - to avoide i floored it, only to have both the front tires smoke for about 20 feet as i turned... waste of rubber. I WANT SUMMER!
Old Feb 27, 2003 | 08:50 AM
Dave B's Avatar
Not DAVEB the parts guy
Get new summer-rated tires and you'll barely spin them.
Dave
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
