those with IS300/roof mount antennas
Old Apr 6, 2003 | 12:10 AM
Nismo's Avatar
How exactly is it mounted? What type of hardware is holdign it down? I know you drill a hole but what exactly is the process of the install? and also how does the wiring from the stock antenna go to the roof mount? easy to do? or does it require me taking off the whole headliner and all?
Old Apr 6, 2003 | 10:40 AM
thebigsadler's Avatar
Re: those with IS300/roof mount antennas
It has a threaded bolt on the inside of the antenna and a nut that goes inside the car and threads on the antenna. I put some silicone under the antenna just to make sure there was a perfect seal. Off the antenna should be 2 or 3 wires I can't remember. It will be power, ground (if there even is one) and the antenna signal wire that you will plug into the back of the headunit.
I simply disconnected my stock antenna, and this one works just fine. I believe the antenna comes with a universal clip that you can plug into the back of the headunit or it just plugs in, I know I didn't need anything else but what came with it.
Don't take off the headliner, there are 3 clips along the back and 2 on the sides you can pull off and just pull it down a little bit. A word to the wise, run the wires as close to the middle of the headliner as possible or you won't be able to get it to clip back in place and it will rattle (if you have stereo).
Good luck.. just be careful drilling, that's the hard part.
Jason Sadler
Old Apr 6, 2003 | 03:15 PM
Nismo's Avatar
Thanks for the post Jason. I also want to know what was the price?
Old Apr 6, 2003 | 03:31 PM
95emeraldgxe's Avatar
the antenna on the s2000's look much better, they are a bit thicker and shorter - thats what most of the vwvortex.com members do on their jettas
Old Apr 6, 2003 | 05:03 PM
Nismo's Avatar
If I remember correctly the s2k antenna is a screw on not a roof mount.
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Pnjboyzz
Oct 7, 2015 10:47 PM
sliptap
Sep 30, 2015 05:57 AM
