RVM UDP ... Oil Leak!!!!
#202
Re: Re: Re: Problem with UR UDP
Originally posted by IceY2K1
Could UR have a patent on its design?
Someone should send that RVM email about them copying UR's pulley to UR.
I just called them again to bother them and RVM Rep told me sell my UDP to someone else who doesn't know about this problem, and buy the new one from then again which will have a sleeves on them.
#203
I just sent the following e-mail to RVM . . .
Dear RVM Racing:
I regret to inform you that I and others have asked that your UDP Group Deal in the Group Deals Forum at Maxima.org be locked and that your firm be added to the "Bad Sellers" list. It is clear from my conversations with Unorthodox Racing that you have been untruthful in stating that UR manufactured an unsleeved pulley for the Nissan Maxima. It is equally apparent that you have no intention of standing behind your UDP even though you freely admit that the oil seal will abrade the bare aluminum of the pulley and in documented instances, cause the engine to leak oil. (I am also aware of other problems with your UDP concerning the timing ring attached to the pulley.)
If you can prove that you are in possession of an unsleeved Unorthodox Racing pulley for a Nissan Maxima and you resolve the timing issues with your pulley, I will retract my request that your thread be locked and request that your name be removed from the "Bad Sellers" list.
#204
Re: I just sent the following e-mail to RVM . . .
Originally posted by y2kse
Dear RVM Racing:
Dear RVM Racing:
#205
Re: Re: Re: Re: Problem with UR UDP
#206
FYI: UR Pulley at UDP
Guys,
I stated that I gave the folks at UR my pulley, but I don't know what they are going to do about it. They stated that the pulley would soon be featured on their web, but I don't want to know what they want to do with it.
As far as sending damaged RVM UDP to UR, I don't have a clue whether you guys could get discounted price or not. However, I do know that they have my pulley (and it's brand new, never installed!).
#207
Re: FYI: UR Pulley at UDP
Originally posted by ardika
Guys,
Guys,
#208
Re: Re: FYI: UR Pulley at UDP
Perhaps you could...since the pulley that I gave them was brand new. Probably THAT particular pulley would be famous, with pictures of it on the UR website shortly.
BUT, they don't have the picture of damaged crank pulley....
Try them!
Try them!
may be i can send them my messed up pulley which shows deep dent due to oil seal and get some discount out of it
#210
Hey guys what so you think I should do :
1) If i can get my money refunded(anyone else get their money rufunded or is it a lost cause?)and get the definitive pulley since its cheaper then the unorthodox.
OR
2)just install this one and use it until it starts to leak then complain and get new one from definitive.
I'm just spending so much money on mods right now that i don't want to spend any more then i have too. Damn this sucks
OR
#211
OR
OR
#212
Do NOT install the RVM pulley. If necessary, write it off as a cheap lesson in purchasing inferior mods for your Maxima. That's what I'm prepared to do.
Oh well, as you've said, cheap lesson learned!
#213
OR
OR
#215
i recently e-mailed UR about their pulley and they said that they did have sleeves on all their pulleys.. but they also said...
"Every one of those parts that leaves this facility includes a sleeve. It is certainly possible that soemthing may have gotten out without one but we include the check in the instructions to make sure the owners check the pulley before they start installation to make sure it is there.
Thanks for your interest,
UR "
so it could be possible that RVM did get a bad one from UR to copy from.. but it does not put RVM off the hook..
UR "
#216
UR "
UR "
i'm not upset over the bad UDP by RVM, but i'm very upset over how they are approaching this matter.
#217
Originally posted by 97MaximaSE
can someone post definitives site....i might just order a new one to be sure even though i have no problems yet... any clue as to what belts they use?
#218
#221
Originally posted by 99maximagxe
has anybody gotten a refund from rvm?
#223
RVM Trader Rating
For those who are disgusted with RVMs unwillingness to correct the problems with their UDPs, here's your chance to get even.
Follow my example and give RVM a negative trader rating. Here's where you go to do that:
http://forums.maxima.org/member.php...fo&userid=12786
Look in the "Member statistics" section under "Trader Rating"
RVM Racing
RVM Racing
litch
123
01-04-2024 07:01 PM
06-06-2017 02:01 PM
