starting problem... is it tranny related?? HELP
Old Apr 15, 2003 | 12:15 PM
nadir_s's Avatar
vicodin ... gift of life
hey guys, i need ure expert opinion on this...
I got out of class and was going to go to work... then my car gave me some problems. Well, i tried starting it and it would turn over but not actually start. I tried about 5-6 times when it actually did work. The weird thing about it is when i would stop trying to start it, i'd hear this clunk sound. This isn't the first time it has happened either... about a month ago i got something similar to this but it started the next try. When I got home right now, I tried starting it and it didn't have a problem... i guess ill try in a while.
Now the key here is I've had differential bearing problems. It's the standard whine in gears, leaking, blah blah blah... except i've pushed the f-ed tranny for over 10k miles lol.
It has been making a couple new interesting sounds... i think it's about to die. I just want to know if the starter problem could be connected to the tranny... or is it my starter?? I thought I wasn't pushing the clutch in all the way or something but I was. Any thoughts?? ANYTHING would be useful, thanks guys.
Old Apr 15, 2003 | 01:43 PM
njmaxseltd's Avatar
Re: starting problem... is it tranny related?? HELP
Check your crank sensors both REF and POS.
Check your cam shaft position sensor.
The clunk might be starter related, but as long as your starter in engauging and cranking your engine, leave it be.
Old Apr 15, 2003 | 04:03 PM
nadir_s's Avatar
Re: Re: starting problem... is it tranny related?? HELP
thanks for the info, ill search around and check out if they're the problem.
1 more thing, can anyone tell me how the transmission and starter are connected? The only thing that comes to my mind is the sensor that says the clutch is in... but how about mechanical-wise? Could my tranny internals be so f-ed up that it could cause a problem? thanks
Old Apr 15, 2003 | 09:51 PM
† ErV †
i dont think they are connected. the starter turns the engine. the engine is connected to the starter only when you crank it anyway. perhaps your neutral gear (or something) is sticking a bit and preventing the engine from turning over properly.
jfl330
Sep 4, 2015 01:44 PM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
Lowered_a33
Sep 1, 2015 07:49 PM
