I need help with remote start
Old Jan 20, 2001 | 03:36 PM
nismo96max
I have a 96 GXE 5 speed and my buddy put in the Viper 550HF alarm with remote start. Unfortunatelly he didn't connect it right, whenever I remote start my car, everything is fine, except the accessories don't turn on (heat, AC). They turn on as soon as I put the key in. Is anyone familiar with that setup, which wire is missing?
Adam
Old Jan 21, 2001 | 12:07 AM
ericdwong's Avatar
Does the radio turn on? If that is the case, he reversed the Ignition and the Accessory wires. You want the ignition wires to be connected and not the accessory wires (so the radio and cig plug wont be operating under remote start mode).
Old Jan 21, 2001 | 12:34 AM
Matt93SE's Avatar
STFU n00b!
yup.. as he said.
check to make sure it's hooked up at all. if you don't have the +12v output to the ignition wire for the heater, then it won't come on.. on my GF's altima, there were seperate wire connections for the engine ignition and the heater/accessories ignition. I would assume they're similar, since hers was a '97 and the wiring scheme on her car and my '93 Max are almost identical.
Old Jan 21, 2001 | 02:33 AM
nismo96max
As a matter of fact, my radio does work, now the only thing, how do I find the right wires???
Old Jan 21, 2001 | 10:49 AM
EZEMaxima's Avatar
make sure you check
that both of you ignition wires are connected. We have double ignition wires. yup that's two and make sure you didn't switch the connection with the accessory wire. To locate it, you'll have to remove the lower steering panels to get access to the ignition switch. That is were your friend most likely had connected it to. And to add another accesory outputwire from your alarm, you might have to wire up another relay. If you got the newer alarms ,it should had come with a prewired second ignition output.
Old Jan 21, 2001 | 11:45 AM
xHypex's Avatar
I was looking to add a Clifford Avant Gaurd 4 to my 99 Max, but the shop will not put a remote start in a 5spd for insurance reasons. How hard is it to wire only the remote start portion of the alarm.
Thanks.
-hype
QueensMAX
Sep 15, 2015 04:14 AM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
