drilled and slotted rotors ?
Old Apr 23, 2003 | 04:47 PM
maxspeed96CT's Avatar
The original VQ...
I want to upgrade my brakes slitly but i dont have much money for a complete brake upgrade kit, i am thinking of gettin drilled and slottled brembro rotors but my friend told me drilled suck. Some one give me some advice on what i should do.
Old Apr 23, 2003 | 05:07 PM
metallic97gxe's Avatar
Master Will
I have the drilled and slotted rotors..
and don't regret buying them at all!
Old Apr 23, 2003 | 05:16 PM
EZEMaxima's Avatar
Re: I have the drilled and slotted rotors..
BUT they are not BREMBO rotors. I got it from IRotors
Old Apr 23, 2003 | 05:22 PM
looney662's Avatar
And they look so da** nice!
Sean97SE's Avatar
Re: Re: I have the drilled and slotted rotors..
Originally posted by EZEMaxima
Old Apr 23, 2003 | 06:10 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Instead of just putting those "one-up" smilies, can someone list the benifits of a slotted and x-drilled rotor over the stock one? And which is better, the "copper" looking one, or the "stainless steel" one? I was talking to some org members and they told me that cross drilled/slotted (brembo) rotors worsen braking performance becuase theres less surface area. The only benifits they have is they are a lot less prone to warping. But why the hell would someone pay all that money for something that is less prone to warping, yet decreases breaking performance?
Old Apr 23, 2003 | 06:32 PM
njmaxseltd's Avatar
Better pads will yield you better brakes. The pad is what generates the friction which makes you stop.
If you don't want to spend a lot of $$$ upgrading your brakes, just get some nice pads on your car. Drilled or slotted rotors look nice and perform quite well. But the real stopping power comes from the pads.
Old Apr 23, 2003 | 06:41 PM
Craig Mack's Avatar
Thanks for the pad info, but you still didn't answer my question(s)
Old Apr 23, 2003 | 07:26 PM
bert's Avatar
Pads first, rotors second (because they are genereally half dead in the first place), brake fluid fourth, calipers third, SS lines fourth.
Pads generate heat.
Rotors absorb heat.
Brake fluid is tollerant to heat.
Calipers generate more heat.
SS lines don't get affected by heat.
Old Apr 23, 2003 | 08:21 PM
Slickismax's Avatar
here ya go
http://www.avalonracing.net/rotors.htm
Old Apr 26, 2003 | 04:21 AM
optimus1's Avatar
heat vs pressure
SS lines give you instant pressure transfer, expansion resistant ...
Old Apr 26, 2003 | 09:28 AM
foodmanry's Avatar
Da Roller Coaster!
Re: heat vs pressure
B/C of the higher specific heat of stainless steel vs. the rubber.
Apr 16, 2020 05:15 AM
sliptap
Sep 30, 2015 05:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
dcam0326
Sep 18, 2015 04:52 PM
A32goldylocks
Sep 2, 2015 06:39 AM
