Signs of clutch slipping?
Old May 5, 2003 | 01:43 PM
djshawnee's Avatar
Hey guys, I want to know what happens when your clutch slips? Because lately (meaning the last 2 days), it has been harder and jerkier to start in 1st, and 1st-2nd shifts are always very jerky..... even from 2nd-3rd. Also, ya know when you are in a race and your dash shakes violently? I have started getting that a lot now..... but much less severe, it happens on a miniature scale, even going into 2nd gear. Is my clutch slipping? How long will it be before I need a new clutch, or do I need to get one immediately? I have 79k on my car. Please help me out, thanks a lot!
Shawn
Old May 5, 2003 | 01:51 PM
njmaxseltd's Avatar
You have clutch chatter.
That could be caused by contamination, glazing of your clutch disk or a warped flywheel.
It's time to service your clutch.
Old May 5, 2003 | 02:15 PM
djshawnee's Avatar
what exactly does service mean? does that mean that i have to replace the clutch? or where do i take it?
how much is this going to cost?
Old May 5, 2003 | 06:21 PM
njmaxseltd's Avatar
Service means take it out and inspect it to see what's wrong. With 79K on your car, you put a new one back in as long as everything else is OK. Clutch chatter could be caused by oil leaking from your rear main seal onto the clutch disk. Replace the seal if thats the case before you put the new clutch in. If you flywheel is glazed, burnt or warped, have it resurfaced.
Old May 5, 2003 | 07:28 PM
djshawnee's Avatar
how much does this all cost? and do i just go to any transmission shop?
Old May 6, 2003 | 08:44 AM
NYCe MaXiMa's Avatar
clutch replacement typically runs 250-350$ for labor only. Parts will cost you around 200-250$
I get clutch chatter as well.
If your clutch was slipping, you'd literally feel it slip. Sure way to test it is to put the car in 5th gen while cruising at like 40 and give it gas, if the RPMs go up but the car is not gaining speed, then you know it's not well.
Mine does not slip, but it chatters like crazy, my pedal is very stiff and it's just feeling rough overall.. From what I understand the pressure plate and/or the throwout bearing may be causing this. Either way, to change it, you have to remove everything, so might as well replace everything while you're in there.
Old May 6, 2003 | 08:51 AM
SonicDust187's Avatar
Steve, what does chatter feel like?
Old May 6, 2003 | 02:56 PM
bonzelite's Avatar
i have the clutch chatter prob as well in lower gears at low rpm's. it is time to replace the whole thing. flywheel included. waiting for the funds.
Old May 6, 2003 | 03:08 PM
djshawnee's Avatar
ok the weirdest thing happened.... i was getting this clutch chatter yesterday and this morning.... but when i got in my car after school today, everything was FINE... even better than fine..... shifting as smoother than ever before and my engine "hiccups" were drastically minimized in 1st and 2nd...... i have no idea how this could have happened..... i mean it is good and all, but i am just puzzled.
should i still take it to be checked out?
Old May 6, 2003 | 03:55 PM
bonzelite's Avatar
the chatter may come back. the clutch plate and flywheel contact 'dynamic' may have found a temporary sweet spot. who knows. i'd bet it will be back. if something is worn, it will not unwear itself. maybe the car has arthritis. try giving it some excedrin.
Old May 6, 2003 | 04:04 PM
Jeff92se's Avatar
I'm needing a caw
If you need to replace everything. Buy the fidanza from me $325+ shipping. Group deal forum.
Old May 6, 2003 | 08:45 PM
djshawnee's Avatar
what do you mean by 'everything'? what is everything that will need tp be replaced?
Old May 7, 2003 | 11:46 AM
Jeff92se's Avatar
I'm needing a caw
Clutch disc, Pressure plate, throw out bearing, pilot shaft bearing. If you are in there, it's a perfet time to upgrade that boulder of a flywheel with a nice lightweight one.
Old May 7, 2003 | 09:22 PM
car studders and shakes like a b-tch as the clutch begins to grab. depends how bad it is on your car if you even have it at all.. but mine makes the care almost undrivable until it's fully warmed up.
Old May 7, 2003 | 09:31 PM
bonzelite's Avatar
right. mine is getting to be that way as well. the question is this >>> which hi-performance clutch is a great choice for the 3rd gen? i have heard mixed stories on these forums, btw. from some research, i have steered away from ATC, as that was once a possibility. now i am seriously considering Exedy. another question arises as well >>> what type of clutch disc is best? i am looking at the kind with the "pucks." as far as i know, the kind with the tri-puck design is nearly only for race applications and would wear out too soon for street use. whether this is true or not is beyond me at this point. i'm no clutch expert.
Old May 8, 2003 | 04:42 AM
Nope no clutch chatter cause my car doesn't shake.
Old Jun 12, 2003 | 08:45 AM
djshawnee's Avatar
how much does a new OEM clutch cost? And how much would it cost to have the clutch installed, and the flywheel resurfaced?
Old Jun 12, 2003 | 02:04 PM
PCGuRu2K's Avatar
You should drive in mines.. I get a lot of chatter.
Old Jun 12, 2003 | 02:09 PM
I want to but I am never in Queens to chill with you guys. Maybe at the meet.
Old Jun 12, 2003 | 04:39 PM
OEM clutch assembly can be had for around 200$ last time i checked. Look at courtesyparts.com.
as far the intallation.. it was mentioned earlier in this thread. 250-350$ for the labor, which my guess includes the flywheel resurfacing.
I'm getting ready to do mine in a couple of weeks. Freakin car is barely driveable. Clutch doesn't slip but it is very rough.
user 11122324
42
Jul 18, 2022 03:35 PM
carlosvq30
Sep 26, 2015 09:44 AM
homewrecker
Sep 24, 2015 07:01 PM
