I need belts for my UDP....got some Qs
Old May 6, 2003 | 10:33 AM
luckee2bhere's Avatar
I found this on MaxFaqs:
"What size belts will I need for the UDP since it is smaller?
The part number you need are: Gates K060408 and K040292 or K040300. If your local parts store does not carry Gates belts, they will be able to tell you the part numbers for the brands they carry."
Ok so I need: Gates K060408
K040292 or K040300
Why are there two choices for the second belt?
Is there different quality of belts?
Recommended brands?
Anything else I need to know?
Old May 6, 2003 | 10:59 AM
xHypex's Avatar
http://forums.maxima.org/showthread....highlight=belt
-hype
Old May 6, 2003 | 11:23 AM
all that reading and i dont think i learned anything. my brain is mush from finals. can you spell it out for me?
Old May 6, 2003 | 11:42 AM
xHypex's Avatar
If you read the 3rd post down from the top you'd see:
From
http://forums.maxima.org/showthread....&highlight=UDP
While we're speaking about belts I bought 3:
Alternator & Water Pump
1995-02 Gates # K060408
Power Steering
1995-02 Gates # K040292
If this one does not fit then try: Gates # K040300
I tried to fit the K040292 and there was NO way it would fit. I ran the adjuster all the way down and it was still too tight to fit on. I used the K040300 with no problems though
I hope you do better reading your books than you do threads
-hype
Old May 6, 2003 | 11:45 AM
Jime's Avatar
Yes buy the K040300 not the K040292 which is too short. One is 30" and the other is 29" I ran into exactly the same problem.
05' MaximaMan
Oct 8, 2017 06:36 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
markevans999
Oct 25, 2015 08:27 AM
homewrecker
Sep 24, 2015 07:01 PM
2kmaximel
Sep 24, 2015 03:55 PM
