Ever Plug your Z-Rated Tire after a Nail Puncture?
Old May 12, 2003 | 12:17 PM
ZuMBLe's Avatar
Never plug. Always patch.
Old May 12, 2003 | 12:22 PM
Sprint's Avatar
0w3nd by Zum Zum Zum
Old May 12, 2003 | 12:36 PM
Jepht20's Avatar
Custom User Title...
i'm new to knowing anything about tires...can you explain how patching works? i've gotten plugs on my old tires but not on my new wheels which i need to do, there are 3 screws in them are they too soft for plugs? someone mentioned something like that once.
Old May 12, 2003 | 03:59 PM
Nismo's Avatar
when you plug the tire, dont you also put a patch on the backside too? so just leave out the plug or what
Old May 12, 2003 | 05:24 PM
carnal_c30's Avatar
Former Sponsor
yup confusing me too
if I do patch/plug a tire I wont use it on the track anymore... just on the street yea?
Old May 12, 2003 | 06:29 PM
boba001's Avatar
Plugging a tire is an easy way to fix a hole when you're in the middle of nowhere... They sell $10 kits that contain a hook, rubber strips and some rubber glue. You stick the plug/strip with the hook while covered with glue in 1/2 way into the tire, pull it back out.. it plugs the hole.
It's better to patch the tire, which is taking it off the rim and filling the hole in and sanding the excess rubber of from inside the tire/etc. Plugging weakens the tire and really should only be used as a temp solution.
Old May 12, 2003 | 07:15 PM
ZuMBLe's Avatar
Never plug! By plugging, you're putting stress on the tire. On top of that, most plugs can't get a airtight seal. The tire flexes a lot while rotating and the plug will eventually work its way out.
Patching is much better. A patch applied properly is just as good as not having a hole at all. The person patching the tire should inspect the inside of the tire and sand down the area of the puncture. They should then use air to blow any rubber from the sanding away. A special heat activated glue is applied to the area and the patch is put on. They then use a roller on the patch to make sure all the air is out and there is 100% contact. The patch will flex with the tire and be just as strong as the original rubber if not stronger. Patches can't be used on the sidewall or near the sidewall. Never plug! It's really painful watching someone plug your tire too!! They stab it and stab it.. then they stab it some more!
ZuM
Old May 12, 2003 | 07:31 PM
Nismo's Avatar
toyota teaches me to first ream out the hole then pull that plug rubber material through it then sand/grind the rubber down from the inside, apply the rubber compound along with a patch. does that sound right?
Old May 12, 2003 | 08:53 PM
ZuMBLe's Avatar
I don't see a reason to use the rubber plug at all. Why would you do that? Adding more rubber also means throwing off the balance of your tire more.
Old May 12, 2003 | 10:27 PM
Nismo's Avatar
protecting the vunerable patch from rocks sand ect that can seep into the tires crack/hole and damage the patch?
Old May 12, 2003 | 10:35 PM
Matt93SE's Avatar
STFU n00b!
I've patched probably a dozen Z rated tires and NEVER had a plug come out, throw the balance off, or leak. not saying it doesn't/won't happen, but so far, I've never had a bad experience with them. I don't even bother taking the car to a tire shop when I get a flat anymore, because even the GOOD shops around here just stick a plug in it and charge you $10. even if I request a patch, they don't mess with it and send me out the door with the plug.
Old May 13, 2003 | 03:28 AM
carnal_c30's Avatar
Former Sponsor
sounds right the correct way eheheh
Old May 13, 2003 | 11:35 PM
97MaxGurl's Avatar
Chick specializing in rounding up 100+ Maximas
yes
Old May 14, 2003 | 10:24 AM
ZuMBLe's Avatar
You'd need a pretty big hole and some pretty bad luck to get something in the exact hole the patch is covering. =P But really, once you pull the nail out, the rubber closes up. Plugs usually aren't flush with the surface of the tire. If anything, I'd think the plug would push the patch off. I dono!
Old May 14, 2003 | 10:39 AM
ZuMBLe's Avatar
I wouldn't trust a plug. All the "good" tire shops should patch. It takes more effort but I really think its the only way to go. You have to see the work that goes in to a patch. I really consider plugging a temp fix or a shortcut. I guess if it works for you keep doing it. I would never let someone plug my tires though. Had it done once and I went to another shop, had them pull out the plug and patch it.
ZuM
Old May 14, 2003 | 12:28 PM
Nismo's Avatar
explain your method of patching and also your method of you were to plug. I was taught to use both a plug material and also a patch.
Old May 14, 2003 | 01:19 PM
ZuMBLe's Avatar
I've never patched myself, always brought to a place to have it done. What they usually do is.
Unmount the tire. Sand down the area of the puncture. They apply some type of glue and blow dry the glue so it dries and becomes sticky. Then they apply a self adhesive patch and heat the patch with the blower. They then use a roller and rub down the patch to make sure all the air is out. Wait a few minutes to set and remount tire.
I had my tire plugged once. I asked if they repair tires and I was stupid enough to think everyone patched. He took my wheel off and started stabbing it with a sharp object. He stabbed at it while mounted on the rim with air in it for about 5 minutes!!! =( Then he applied glue to this "plug" that looked like a Slim Jim. He then shoved the plug in there and turned a few more times and put more glue on the area. It was terrible!! Maybe this isn't how you would do it, but this guy was terrible! So there I was. It looked like my tire got a bloody nose and had a tissue stuck up its nose. This plug is just hanging there. Very unslightly! I drove to my regular tire place and had them remove the plug and patch the tire.
The way I see it, plugging puts unneeded stress on the puncture wound.
ZuM
240tomax
Tires and Wheels
Feb 10, 2016 11:01 PM
Excalibur23
Oct 13, 2015 04:33 PM
homewrecker
Sep 23, 2015 03:41 AM
Serotta33
Sep 17, 2015 12:14 PM
