PaceSetter or B&M Short Shifter?
Old May 23, 2003 | 01:32 AM
BippuBenji's Avatar
I'm still unsure of which one to get, PaceSetter or B&M? What do most people perfer and why?
-Ben
Old May 23, 2003 | 04:49 AM
PCGuRu2K's Avatar
B&M here... It's not adjustable height wise but it sits just as low as the Pacesetter.. Some ppl like the Pacesetter since it's cheaper and serves the same purpose. If not installed right the Pacesetter can be really notchy. B&M is pretty much the same as the Stillen one.
Old May 23, 2003 | 06:12 AM
StygianMax's Avatar
I went with the "value" approach & got a Pacesetter. My only complaint is that to install it, I had to grind down the plastic pivot ball. It was too big by ~1mm dia. to fit in the "holder" thing. I know someone who's had a Pacesetter for 3 years & has not had a single problem (whether notchiness or worn synchro).
Old May 23, 2003 | 06:31 AM
ReddoG_Max's Avatar
trust me..buy the B&M. Best quality on the market..you won't be disapointed
Old May 23, 2003 | 06:44 AM
SonicDust187's Avatar
How did you grind the ball down? I do not have a dremel so its hard for me to do. Can I just use sand paper?
Old May 23, 2003 | 06:50 AM
StygianMax's Avatar
I used a dremel tool. If you have a sander, that **might** work. It might be a little tricky holding firmly onto the ball. if doing by hand, try a coarse grit sandpaper. I know, it's a PITA with the Pacesetter.
I don't think the B&M has this problem. I guess what is you get is related to what you pay.
Old May 23, 2003 | 06:54 AM
Wonder if anyone in NYC can let me get a hold of a dremel?
Old May 23, 2003 | 07:04 AM
StygianMax's Avatar
If you do get your hands on one, the grinding will be a lot easier and controlled.
I shaped mine by grinding the ball down "northern hemisphere" first, then the other; going from from the "pole" to the equator so to speak. Grind a thin layer off at a time & test for fit in the holder so you don't shave off too much.
Old May 23, 2003 | 09:42 AM
maxspeed96CT's Avatar
The original VQ...
I went with the bay 20$ shifter ad i love it. I wasn't about to spend like 100$ on a shifter and i dont like pasesetter so i tryied this one and its great, the hole thing i had to do is bang down the top heat shield.
Old May 23, 2003 | 09:47 AM
BippuBenji's Avatar
Hmm, that grinding issue is starting to make me lean towards the B&M. Thanks guys.
-Ben
Old May 23, 2003 | 11:13 AM
00MAXIST's Avatar
Get the B&M it's high quality and is a full replacement rather than a partial replacement with the Pacesetter.
Old May 23, 2003 | 11:21 AM
BippuBenji's Avatar
Ok, I'll drive the stock one for awhile and then order the B&M from summitracing.com later. Thanks.
-Ben
Old Jun 4, 2003 | 06:48 PM
mitch33x's Avatar
-Ben
ever order the shifter?
Old Jun 4, 2003 | 08:56 PM
96BLUMAX's Avatar
B&M. If you dont believe me come over and drive my car.
Old Jun 4, 2003 | 09:54 PM
95emeraldgxe's Avatar
pacesetter requires modification and its a lil bit cheaper.....B&M no modification, costs a bit more.....take your pick
Old Jun 4, 2003 | 10:05 PM
00MAXIST's Avatar
After two weeks, my B&M is amazing, so smooth, so short. Ahhh...
jmlee44
Oct 2, 2022 02:13 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
atriuum
Sep 28, 2015 01:19 PM
