Air Conditioning....
Old May 31, 2003 | 01:42 PM
taeMAX97's Avatar
Summers coming..... few days ago here in chicago the weather was really HOT... so i turned on the air condition and it seems like it's not performing well. it's still cold but not as cold as it used to be. what do i need to do? and how hard is it? cost?
thanks,
Tae
Old May 31, 2003 | 01:52 PM
njmaxseltd's Avatar
You need to have it tuned up by an A/C specialist.
Old May 31, 2003 | 10:09 PM
Nismo's Avatar
recharge it. when was the last service?
Old May 31, 2003 | 10:29 PM
AscendantMax's Avatar
yea just have it recharged.
check for any leaks while you are at it.
Old Jun 2, 2003 | 09:22 AM
taeMAX97's Avatar
never had it serviced since i bought it back in Jan. 2001. what do you mean by recharging? is it hard to do? what kind of parts do i need?
Tae
Old Jun 2, 2003 | 01:27 PM
95GreekMaxSE's Avatar
autozone.. 2 cans of r143a, 1 can of r134a oil and 1 can of stop leak to check for leaks and maybe even stop a leak (yea rite). You will also need a quick connnect hose that comes with the gauge. First check the pressure with the guage and see how empty it is. If it is completley empty use in the following order, both cans of r134a, then the can of 134a oil then the stop leak. after the last can inspect the hoses and look for leaks. hope this helps. If your a little low then just plug 1 can of r143a and maube a little r143a oil to be on safe side.
Old Jun 2, 2003 | 03:11 PM
masterB's Avatar
does the recharge kit sells at walmart work??
Old Jun 3, 2003 | 08:49 AM
PCGuRu2K's Avatar
Time to juice it up with some freon
Old Jun 3, 2003 | 08:53 AM
redmaxpa007's Avatar
i SeE what you did therE
buy a newer maxima
and you will have AC
Old Jun 3, 2003 | 09:31 AM
atulb84's Avatar
ur car is perdyyy redmax.
Old Jun 3, 2003 | 09:43 AM
not anymore
Old Jun 3, 2003 | 09:46 AM
atulb84's Avatar
wow, what happened.
Old Jun 3, 2003 | 11:04 AM
ZeRo MaX's Avatar
that's not gonna be a cute story...
i recharged mine not too long ago... only one can though.. do i need another?
Old Jun 3, 2003 | 11:33 AM
DanNY's Avatar
Ad·min·is·tra·tor
you have a leak..find the leak and fix it first or you'll be recharging all the time.
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
