Blown MAF sensor on 5thgen Turbo, Moral behind this one....
Well me and bags533 went to the dyno shop so I could see what the car was putting out after we made a few changed like changed out the fmu to the cartech, getting the fuel pump to push 100psi again, and added another fan, alot of other changes that shouldve put me well over 300whp at 10psi. Yeap we cranked it upto 10psi.
So the 1st run wanted to make sure everything was alright, we ran it at 6psi. Cranked out only 200whp, from the last time I ran 5psi I put down near 260whp. So I knew I was running off the chart rich. Below 10:1 a/f. So then I cranked up the boost to 8psi and backed out the fmu a bit. Did a 2nd run to redline and saw it put down only 220whp. But heres where it gets good, near the end of the run the SES light went on and then I thought nothing of it cause we were probably running so rich I threw a code. So cleared it by taking the battery off, came back 15mins to make the 3rd run, and the car would not start anymore. After about 8cranks we got it running but it was idling above 1500 and then we couldnt take it past 2500rpm. So we cut the dyno short and called it day before we took anymore chances and had to push the car off the dyno. So basically had to drive home 15miles in limp mode.
Will do a compression test again to make sure nothing else happened even thought I did one last week. And have to order a MAF.
So basically my point behind all this is You CANNOT push 8+psi on the MAF when it is on the Charged Piping side. Not a single 5th gen is doing that. I know IceY2k1 told me I might have issues, and he was right.
Also probably why the HP was totally off because the MAF was on its way to the wonderful MAF heaven in the Sky.
Dixit
Dixit
Re: Blown MAF sensor on 5thgen Turbo, Moral behind this one....
Originally posted by Ramius83
Dixit, the problems just never end for you and Bags do they? Anyways, are you gonne have to change this as well?
EJJ: Yes, they suck lol.....
Well I bought a MIG welder so we will be redoing the entire kit. Bags will be at my new house Sunday working on his POS while I work on Mine. Im gonna move the MAF to the intake side. Exten the wires and move it there.
Dixit
Re: Re: Blown MAF sensor on 5thgen Turbo, Moral behind this one....
Originally posted by ejj
But lots of 4th gen guys are...is there a difference in MAF's?
Sorry you're having so many problems, Dixit. At least we now know which kit is better... but at your and Kirk's cost.
Re: Re: Re: Blown MAF sensor on 5thgen Turbo, Moral behind this one....
Originally posted by Y2KevSE
So in other words, your MAF will max out before ours.
Re: Re: Re: Re: Blown MAF sensor on 5thgen Turbo, Moral behind this one....
But that doesn't explain why people who are putting them on the charged side have more problems in 5th gens.
Re: Re: Re: Re: Re: Blown MAF sensor on 5thgen Turbo, Moral behind this one....
Well I think for what I know, I was the only person putting the MAF on the charged side of the 5th gens.
Regardless, problems like this suck. Sorry man.
Stephen: Do I smell a, "I told you so" coming.
Originally posted by Stephen Max
What happens when a MAF gets blown? Does the square cover plate become unsealed, or what?
When you burn up the MAF or blow it, same thing. What happens is that the element most likely is burnt, so it cant heat up anymore.
Dixit
Re: Re: Re: Re: Re: Re: Blown MAF sensor on 5thgen Turbo, Moral behind this one....
So it could be a freak thing...
Maaaaaaaybeeeeeeeee. But first I need to find out if a blown MAF is what I think it is so I don't embarrass myself.
On the MAF there is a element, that element heats up and the air cools it down, then the ECM heats it up more to maintain the certain temp. That is how a MAF works.
Dixit
Dixit
Re: Re: Re: Re: Re: Re: Re: Blown MAF sensor on 5thgen Turbo, Moral behind this one....
Sort of like a light bulb filament burning through? So how does the boost pressure cause this?
Dixit
Re: Re: Re: Re: Re: Re: Re: Re: Blown MAF sensor on 5thgen Turbo, Moral behind this one....
Well I got a feeling when I was pushing 8psi and the element was heating up to try to get the temp on it, and then it hit the rev limiter and it basically cut the air flow in a split second and the element at split second overheated and burned it self up.
Dixit
Dixit
I think I might get a shift light, since I tend to hit the rev limiter occasionally, what with keeping my eyes on the EGT gauge while trying to get the most out of the MEVI.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Blown MAF sensor on 5thgen Turbo, Moral behind this one....
That makes sense.
That makes sense.
I've considered dropping money on better guages that have memory/playback features just because of this. Too many damn things to watch!
J/K...man I don't have a clue why SC'd 4th gens. can get away with it, but Stillen later changed the design so that tends to suggest they were having issues.
Anyways, I'd just buy the element from DAVEB for like $50-$75 and see how long it lasts. If you fry another one, I'd move the MAF and HEAT SHIELD that bish. Also, you might consider going with a Pathfinder MAF like Mardi did. Or maybe a 350Z/G35?
Well Alex, I think im going to just move it over to the intake side. I think that is the correct place and then redyno the car again.
I hope things start to go smoother...keep up the fight.
You dont know what I can do with a welder, Im going to weld the hell out of a rack of things. I basically went to home depot and bought a bunch of odds and ends metals and just going to weld everything. Watch me, Im going to be looking for things to be welding in the house/car, just a new toy
BTW, did you ever get your keyless entry to work?
Alex got it to work, for some reason the unit was jacked up. When the battery went dead on my car over 2weeks when i didnt drive it, and I jumped it and after that never saw the problem again, probably cleared the problem.
Good idea on the HID theft, I can weld some bracket on that bad boy. But then again the car is always parked in a garage. But I can make one for you guys.
You might want to get 2 sets of helmets or a helmet and a set of goggles. So you both can see during the learning process. Also 2 eyes are better than 1 sometimes.
Once you get it to puddle move at a steady pace and you'll be all right. If your going to be doing a lot of practice get some long gloves or wear an old long sleave shirt. Don't want sun burned arms
My roomate is an iron worker and he has shown me quite a bit. He's aslo come home many days with burnt arms and neck, even right under his nose. I'll ask him if he was outside all day. Most of the time he says nope...
Yea so do I Youll see Sunday. We'll start off with welding some crap to your car first, hahha
you'll be welded as the hood orament if you make it look worse than it is..lol
Originally posted by bags533
...if you make it look worse than it is..lol
See who welds better. The muffler shop 'expert' or someone who's never even welded before, Dixit.
This could be worth a few pics.
your cars gonna be the 2ND car he welds on
if you dont' have a flex section yet, i suggest that u add one. if there's not enough room for the down pipe that goes vertical (which i doubt there would be room) add one right after the vertical bend because you want a flex section there due to the engines rotational orientation. because if you don't u'll end up stressing on parts that you dont' want to. since you have a mig welder now, i suggest that you build your own custom maf sensor tube out of metal. my friend built one on his TT and it works great. perhaps even going with an aftermarket maf might better your situation. i haven't seen anyone go that route, but it doesn't seem like a bad idea.
litch
123
01-04-2024 07:01 PM
TallTom
50
07-08-2022 09:54 AM
