need help with EGR system
Old Jun 6, 2003 | 12:57 PM
Soon2BMaxed's Avatar
well ever since my car threw the code for the EGR temp sensor it has run like complete SHlT. i have a huge loss of power and the car just sounds unhealthy.
a mechanic told me that the egr valve may be stuck open for some reason causing it to dump exhaust constantly instead of just at idle speeds. this would explain a lot.
he said that i could try unhooking the harness (if there is one) for the egr valve and seeing if it would just completely shut it then i'd know that that was what was wrong.
can anyone put up pics or tell me where the harness or actual valve are located?
my chilton's only shows pics of the one on a VG
Trevor
Old Jun 6, 2003 | 10:12 PM
Old Jun 7, 2003 | 11:17 PM
Old Jun 8, 2003 | 04:40 AM
njmaxseltd's Avatar
If the EGR valve was stuck open your car would have a really tough time idling. You'd probably also have a code for the valve itself. (0515)
Old Jun 8, 2003 | 09:50 AM
well i have no idea of what it could be then
maybe a knock sensor? myt gas mileage hasn't been great but it hasn't been "terrible" either.... do you know how i can check it?
Old Jun 8, 2003 | 10:56 AM
njmaxseltd's Avatar
You can measure it with an Ohm meter. Should have very high resistance, like 10 Meg Ohms. There's really no sure test for that sensor.
Old Jun 8, 2003 | 03:45 PM
what are the main symptoms of a bad knock sensor?
Miket2006
Mar 1, 2021 03:55 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
bumpypickle
Sep 19, 2015 01:07 AM
