limited slip maintenance
Old Jul 16, 2003 | 01:57 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
I posted in the 5th gen section a while back about maintenance of the stock lsd i have in my ae. I know the unit contains fluid, something similar to gear oil I assume but what are the maintenance specs on it? At what interval should I look at a fluid drain and what is recommended to go back in? I contaced some ae owners but no one had any ideas. I figure with the aftermarket ones out and the ones coming stock on 2k2-2k3 that someone might have some more info.
Old Jul 16, 2003 | 02:02 PM
Jer's Avatar
Jer
Nothing you need to do aside from making sure your regular ATF isn't burnt or breaking down.
Old Jul 16, 2003 | 03:10 PM
blizz20oma's Avatar
I'm so hood
I haven't done much reading on LSDs but I've seen an owners manual give a couple tire-related warnings for the drive wheels (front for the max, obviously). Tire pressure should be closely watched - both tires should be the same pressure. Tires should both be of the stock-recommended size. Obviously this means it's bad to use the spare on the front, but HOW bad factoring in the total time spent on a spare is something I don't know.
Failure of the above conditions according to the manual could result in the LSD working at all times which can compromise longevity.
Old Jul 16, 2003 | 03:39 PM
sloppymax's Avatar
well im guess im screwed then. i had a blowout on the front right so i had to run doughnut for 2 days and then im running 235/50/17 on prophets. as far as tranny, i flushed it at 25k with mobil 1 atf with a tranny cooler. i guess i was thinking there was a control unit or something with a drain plug on it somewhere- so what you are saying is that is uses the atf to lubricate the lsd?
Old Jul 17, 2003 | 11:42 AM
Jer's Avatar
Jer
There is no indivudual source of lubrication for the LSD. It all comes from the same source and uses the same transmission fluid.
Old Jul 17, 2003 | 01:24 PM
optimus1's Avatar
should keep donuts on rear if possible, more safe. unless you are a cop, then they're on the counter ...
Old Jul 17, 2003 | 02:31 PM
sloppymax's Avatar
i hear ya, i was actually going to bolt on someone else's full size but blubyu2k2 did not have any lights in his parking lot.
Old Jul 18, 2003 | 06:48 AM
Blu's Avatar
Blu
the tits
DOH....you and erin are going tonight with us too watch Bad Boys 2 right. YGPM
TKHanson
Nov 24, 2018 01:39 AM
homewrecker
Sep 24, 2015 07:01 PM
pears
Sep 18, 2015 05:25 AM
Jay556
Sep 12, 2015 05:50 PM
crazyespn
Sep 3, 2015 01:30 PM
