GC coilover noise
Old Aug 6, 2003 | 08:32 PM
99maxi's Avatar
GC coilover noise
what kind of noises are you guys getting with GC coilovers? i get clunking sound when going over bumps. has anyone found a way to get rid of the weird noises??
Old Aug 7, 2003 | 02:35 AM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
Get spiral wraps from radio shack and wrap the first 2 top coils and the bottom 2 coils and it should get rid of the clanking noises.
Old Aug 7, 2003 | 06:24 AM
rob van dam's Avatar
i dont think the spiral wrap will help. I had that noise a long time ago and to fix the problem, the rear suspension was taken apart and redone a different way. Now my gc's are just fine
Old Aug 7, 2003 | 06:43 AM
ejj's Avatar
ejj
Whats the "different way"?
I was getting clunking, so I wrapped the rear springs in sprial wrap, and it helped things quite a bit.
Old Aug 7, 2003 | 07:33 AM
We just put this washer underneath the rubber at the top of the rear suspension rubber bushing thingy(<LOL) so that it wouldn't move. That was a horrible explanation...i would need to show actual pics of what was done...
Old Aug 7, 2003 | 08:51 AM
Deac's Avatar
Re: GC coilover noise
All coilovers make noise.... I have'nt heard of a set that are completely quiet yet! Thats part of the price you pay for modding unfortunately.
Deac
Old Aug 7, 2003 | 09:12 AM
DEAC...i want to see NEW pics of your car...cf hood..turbo..new rims..etc etc
Old Aug 7, 2003 | 10:39 AM
Dreizehn's Avatar
Re: Re: GC coilover noise
Deac
My GC's don't make any noise.
Old Aug 7, 2003 | 11:10 AM
99maxi's Avatar
my rear is fine, no noise at all. but it is just the front.. makes noise over small bumps..
Old Aug 7, 2003 | 11:36 PM
Dev's Avatar
Dev
my rear doesn't make any noise
just the front makes noise when turning...like squeeking
after 3 or 4 turns it goes away
Old Aug 8, 2003 | 12:03 AM
Iilac's Avatar
My GC don't make any noises going over bumps. It does during when I am turning now but that is just because I have to regrease the top cap so it will glide from the strut mount.
Old Aug 8, 2003 | 12:06 AM
Dev's Avatar
Dev
which part is the strut mount? the triangular part that has 3 bolts going through the strut tower? or the part that used to be the top hat for the stock spring?
Old Aug 8, 2003 | 12:09 AM
Nismo's Avatar
he means grease the top of the top hat and strut bearing so that it will stay on the strut mount
Old Aug 8, 2003 | 12:13 AM
Dev's Avatar
Dev
what i was trying to ask is if you guys kept the stock part that was on top of the stock springs...i took it out...but im wondering if that might be causing sounds
right now i have the aluminum top hat, the strut bearing, then the top mount (with the 3 bolts going throught he strut tower)
Old Aug 8, 2003 | 12:16 AM
Iilac's Avatar
I have that too, the top hat, the strut bearing and the top mount on the front coils with spiral wrap. What stock part did u take out?
Old Aug 8, 2003 | 06:22 AM
Dreizehn's Avatar
That's how I'm setup and have no noises. I originally left the top spring perch in and it made noise so I redid the suspension and took it out. No noises since.
Mine sits, strut, spring perch with o-rings, spring wrapped with radio shack wire loom, aluminum top hat, strut bearing, stillen camber plates...
Old Aug 8, 2003 | 08:04 AM
ThurzNite's Avatar
The se-r guys wrap their struts in duct tape, then use silicon gasket sealer on top of that...slip the sleeve over and screw. No more rattling.
Jae
Old Aug 8, 2003 | 08:35 AM
99maxi's Avatar
what is the spring perch??
this is what i have from top to bottom.
sturt mount, strut plate with the 3 screws, strut bearing, aluminum top hat, and then springs with spiral wrap, right now i think it is the spring making noise. how did u guys wrap the springs? i did the same with the silicon and duct tape. it worked pretty well.
Old Aug 8, 2003 | 12:12 PM
96BLUMAX's Avatar
Yeah add helper springs.
Old Aug 8, 2003 | 12:56 PM
Dev's Avatar
Dev
i have spring wrap only on the bottom 2 coils
would it make a difference to wrap the top coils?
Old Aug 8, 2003 | 01:13 PM
99maxi's Avatar
what are those??
Old Aug 8, 2003 | 08:45 PM
ThurzNite's Avatar
Weapon-R's coilover uses helper springs.
Jae
Old Aug 8, 2003 | 10:17 PM
Iilac's Avatar
Yes, wrap the top first two coils as well.
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
Garrettz459
Sep 28, 2015 02:50 PM
