Cars is feels slower at WOT as oppose to partial throttle
Originally Posted by spirilis
I think it's possible, if the fuel system is clogged/dirty or otherwise not pumping fuel quite as much as it should, that the Closed-Loop fuel trim ends up richer than open-loop (i.e. at open-loop, the mixture is too lean due to a fault in the fuel system, thus in Closed-Loop it compensates by using positive fuel trim values)... thus flooring it would run LEAN, not RICH, and backing off would put it back into positive fuel trim (Open Loop = fuel mixture computed from MAFS/ECT/IAT/etc, then in Closed Loop it uses Fuel trim values which define a percentage + or - open loop's mixture)
An OBD-II sensor scan tool might shed some light into that scenario, if it exists...
I think you might have some of your terms switched around.
Closed-loop = normal driving, stoich mixture, active feedback from sensors.
Open-loop = >90% throttle, rich mixture, no feedback from sensors.
If the fuel system is a bit clogged as you suggest, all of the sensors in the system will work to compensate for that during closed-loop normal driving and keep the mixture where it's supposed to be for emissions. If it can't, you'll get an SES light.
If flooring it (open-loop) was running leaner, then the engine would have even more power since it normally runs very rich in open-loop. Guys lean out their fuel with S-AFCs on the dyno just for this reason. These guys are saying they have less power, not more.
I think I had my terms correct, but I was misunderstanding the purpose of open-loop (didn't know it intentionally runs rich in open-loop, I figured it just computed fuel delivery to match stoich as close as possible based off inputs from MAFS/ECT/IAT/etc, without the accuracy of having an O2 sensor to tell it whether it was correct)
Originally Posted by gtr_rider
This is one of those threads that makes all the sense in the world. What about us 95'ers that are running on OBDI?
Great link stevey.
Great link stevey.
Originally Posted by Jime
Are you sure its OBDI, my 95 was made in 04/94 and its OBDII.
http://forums.maxima.org/showthread....highlight=OBDI
Lakersallday24
Jun 16, 2019 01:35 AM
Finkle
Sep 27, 2015 09:53 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
kirkhilles
Aug 8, 2015 10:53 AM
