How many miles are you using your 300ZX fuel filter for?
Old Sep 14, 2003 | 12:15 PM
deezo's Avatar
Every 20 to 25K?
Old Sep 14, 2003 | 12:44 PM
ivelweyz
I'm gonna use mine for 15k-20k, so far there's only 4k on it...
Old Sep 14, 2003 | 01:10 PM
nismos14's Avatar
§è~® f®ÈÄk
whats the benefit of the 300z fuel filter?
Old Sep 14, 2003 | 01:30 PM
Threadkilla's Avatar
lifted and locked
It's quite a bit larger than the one for the Maxima, so you can use it longer. I used the 300z fuel filter when I replaced mine last weekend. It fits perfectly in the bracket on the Maxima.
I will probably change it out at 25K.
Old Sep 14, 2003 | 01:57 PM
Nismo's Avatar
I thought the stock filter is good for 15-20k? and the Z is good for double the time?
Old Sep 14, 2003 | 03:18 PM
ivelweyz
It's the other way around I think...
Old Sep 14, 2003 | 05:09 PM
Matt93SE's Avatar
STFU n00b!
just change it once a year and don't worry about it. for the $5 they cost, it's a non-issue. eat one less cheeseburger and it's paid for.
Old Sep 14, 2003 | 07:51 PM
Stephen Max's Avatar
Oh maaaaannnnn.
Old Sep 14, 2003 | 08:49 PM
Bags's Avatar
VG Ridah's Biatch Hoe
I am plannig on 20 k miles.... i HATE changing the fuel filter
Old Sep 15, 2003 | 06:57 AM
deezo's Avatar
Me too. Thats why I'm using the Z filter.
Old Sep 15, 2003 | 01:59 PM
Kevlo911's Avatar
Kevlo for President
i say 25-30K, stock is 15 and this is double so 30k
i had to cut hte feul line when i changed it
Old Sep 18, 2003 | 11:57 AM
ivelweyz
I don't get why people ***** about changing the fuel filter. It takes 5 minutes and it's as easy as 1,2,5...
Old Sep 18, 2003 | 12:18 PM
costcowholesale's Avatar
I'm at 50k stock fuel filter... should I change it?
Old Sep 18, 2003 | 12:39 PM
Bags's Avatar
you crazy canuks and your wild units of measure...
YES it's due
Old Sep 18, 2003 | 12:41 PM
Padsy's Avatar
Boost.....
I guess I need to change mine..........I'm at 57K
Is it hard to do??
Old Sep 18, 2003 | 12:45 PM
deezo's Avatar
Is it hard to do??
The job is not hard but its more of a pain to manuver your hands in there to get it loose and to remove it. The job gets better if you have ABS.
Old Sep 18, 2003 | 12:48 PM
Padsy's Avatar
Boost.....
I have big hands........don't read ANYTHING into that, its not true
I guess it will be hard for me to get to mine.......where is it on the VQ35??
Old Sep 18, 2003 | 01:04 PM
this guy changed it at like 100k miles/ 160k km
http://www.motorvate.ca/mvp.php/505
how do I get to the bottom hose? how much does the fuel filter cost at your local dealer? I remember my friend buying one and it was like $30 cdn
Old Sep 18, 2003 | 01:16 PM
ejj's Avatar
ejj
I use Z filters, but just change them "when I'm in there". I changed it when I swapped the engine, and whenever I have the intake piping off and I think of it. I've got 3 or 4 of them in my garage.
Old Sep 18, 2003 | 01:51 PM
deezo's Avatar
It should be on the firewall down under your steering pump.
Old Sep 18, 2003 | 03:27 PM
max95q's Avatar
what is a good way to get the hoses off? Or what tool is good to use? I tried to get mine off and I couldnt.
Old Sep 18, 2003 | 05:02 PM
deezo's Avatar
I use pliers to hold the hoses in place while I twist the filter back and forth until it breaks free. You have to place the pliers on the fittings of the filter for this to work.
Old Sep 19, 2003 | 01:37 PM
iansw's Avatar
I use an interior door panel popper around the hose then just pop it off..
Took me literally 40 seconds to do the whole thing.
Old Sep 19, 2003 | 04:56 PM
Nismo's Avatar
installing mine soon, just to check, the output(flat side) is facing on top when mounted correct?
Old Sep 20, 2003 | 04:36 AM
deezo's Avatar
Yes................................
Old Sep 20, 2003 | 10:41 PM
hoodedmunkee's Avatar
does anybody have a diagram on where the fuel filter is found?
Old Sep 21, 2003 | 05:52 AM
Kevlo911's Avatar
Kevlo for President
http://web.archive.org/web/200111091...k_service.html
BkGreen97
Apr 2, 2016 05:47 AM
aminus21
Sep 12, 2015 04:53 PM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
