Smoke from radiator cap??
Old Feb 13, 2001 | 03:29 AM
ZuMBLe's Avatar
I went over to a friend's house last night. Had my car idle in front of his house. I looked over at my car and saw smoke comming out of the grill. I had thought I smelled burning coolant before from inside my car. But it was faint. I wasn't sure. The temp gauge was where it usually was. I opened up the hood and it seemed that smoke was comming out of my radiator cap. My overflow bottle was empty. The cap appeared to be on correctly. But since the car was hot I didn't take the cap off. I drove home and put some coolant in the overflow bottle. I'm going to check it soon when I leave for work. I wonder how much coolant boiled off. I smelled the coolant smell like last week! I don't think I did any major engine damage. The temp has been in the 30s in the day time and the 20s at night. I'm worried about the water pump and such though.
So what would cause smoke to come out from the radiator cap? Anything major that I don't know about? Or maybe my radiator cap is just busted or not put on correctly?
ZuM
Old Feb 13, 2001 | 06:20 AM
DanNY's Avatar
Ad·min·is·tra·tor
assuming the rad cap was installed ok and it's in good condition...
you might have small leak..what you were smelling faintly. prob a lot of it leaked and theres not enough coolant to cool the car..hence boilover. do a pressure test on the cooling system. if there's no leak then i would suspect the water pump going.
Old Feb 13, 2001 | 09:38 AM
ZuMBLe's Avatar
I opened up the radiator today when the car was cold.. And there was coolant in there.. almost full.. I could see it. I turned on the car with the cap off... and the level raised.. I'm assuming that means there is enough coolant.. What do you think? The smoke seems to come out from under the cap.
ZuM
Miket2006
Mar 1, 2021 03:55 AM
05RLS2
Apr 14, 2016 11:49 AM
homewrecker
Sep 24, 2015 07:01 PM
