Why a fuel-cut rev-limiter?
Old Sep 19, 2003 | 11:35 AM
ejj's Avatar
ejj
Is there any good reason that Nissan selected to implement the rev-limiter as fuel-cut? Wouldn't ignition cut be just as simple to implement, and a whole lot safer?
Its just something that's always bothered me.
Old Sep 19, 2003 | 11:39 AM
Jeff92se's Avatar
I'm needing a caw
cut the ign, you still get fuel dumping all over. cut the fuel, you just end up with wasted sparks
Old Sep 19, 2003 | 11:42 AM
ejj's Avatar
ejj
But I would think ignition cut would be safer. Espescially for nitrous use, but I wouldn't expect Nissan to plan for that.
Old Sep 19, 2003 | 05:20 PM
njmaxseltd's Avatar
Cutting the ingition is not safe. If you continue to dump fuel with no spark, you saturate your cylinders and exhaust system with fuel. Then put a spark back and you have the possibility of blowing a head gasket from excessive cylinder pressure and a huge back fire in your exhaust system that can possibly blow your muffler apart.
A neat trick on a motorcycle is to keep your throttle on and hit the kill switch for a 2 second count, then flip the switch back on and you blow an explosion from your exhaust that rattles the neighbors.
Old Sep 19, 2003 | 07:32 PM
MrGone's Avatar
I know all too well about blown mufflers from backfires (mustang). Also the gas > motor oil, so if you have a lot of unburned gasoline in the engine, it will break down the oil. Kind of why you never rev you engine then turn it off, you let it get back to idle for a few seconds.
Old Sep 19, 2003 | 11:33 PM
teejnut's Avatar
How does the speed limiter work? Fuel-cut as well?
95maxrider
Dyno Discussion and Slips
19
Aug 15, 2018 10:43 AM
Thorzdad
Nov 12, 2001 10:28 AM
y2kse
Apr 3, 2001 07:38 PM
jnm2kse
38
Oct 20, 2000 09:33 AM
