nissan has the highest output NA V6?
Old Oct 13, 2003 | 10:52 PM
  #41
Nealoc187's Avatar
SLOW
Originally Posted by IwANnAMaX96
Honda relies on sustaining the torque at high RPM. Doesn't matter if the torque output is low. You can gear is so that the torque is multiplied through short gearing. Just look at the S2000 with "only" 153 lb/ft torque. Besides, in all out racing, only the last 1/3 of the tach matters.
Bingo. Well put.
Old Oct 13, 2003 | 11:05 PM
  #42
Gooey's Avatar
i dont really care i ran my bone stock 2k3 at the track last week and got 14.706 @ 94mph so when i get these blowtenzas off im sure i can pick it up a notch
Old Oct 14, 2003 | 07:22 AM
  #43
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
If you're talking about drag racing and you have an automatic, you come off the line somewhere in the 2000 rpm range and this is nowhere close to the top third of the rev range. And on each shift of the gears there is a big drop in revs that often drops you back into the mid-range. Even if you're talking about circuit racing, you still need torque for strong corner exits.
Domestic iron still does and always will rule the dragstrips because of what they have off the line (massive torque), and what they have through the lower two-thirds of the rev range (more torque).
Old Oct 14, 2003 | 08:44 AM
  #44
MaxSE03's Avatar
Originally Posted by Dave B
I'd take the new TL over ANY Maxima or Altima. Have you guys seen this car yet? It may not be a torquey as the 3.5 VQ, but I'm willing to bet it will be quicker and faster than the Altima or Maxima.
Dave
Guess we will just have to wait on the new TL to come out.
In the mean time, here is the link to the stock 04 Max 5-speed auto run.
14.64 @ 94.56
Old Oct 14, 2003 | 11:41 AM
  #45
grody's Avatar
So here we have it, 14.7s@97mph in the 6 speed from the mags. Remembering that the mags test with an extra 40lbs of test gear and a full tank of gas/spare/etc, 14.3-14.4s are quite possible on a cold day, 1/4 tank of gas, no spare, and a 2.1 60'.
Neal-
You've never seen an auto CL/TL-S hit 14s before? I've watched a bonestock auto CL-S running 14.9@94mph with 2.3 60' at my track. With headers, I've heard from some other racers that he's doing higher 14.5s and 14.6s now. On a sea level track that's a 14.4 second auto with just headers for the only mod.
Dave
Dave, has RussMaxManiac hijacked your computer? I swear that's him talking.
J/K
Old Oct 14, 2003 | 12:22 PM
  #46
CallmeDoc's Avatar
Actually, the TL-S engine made its max torque from 3500-5500 rpm and it has one of the flattest torque curves you will see on a dyno......
By 4800 rpm to 7000 RPM's, VTEC kicks in and the engine roars....so its a very inteligently designed engine. The 5-speed auto will also leave you in VTEC range through the first three gears, which takes you to about 110 mph.
Also, the new TL is basically the Type S engine with a bit higher compression, so I dont see the engines being much different.
Some of you guys need to drive a TL-S or the new TL and then talk.....
Old Oct 14, 2003 | 12:37 PM
  #47
dwapenyi's Avatar
I don't doubt that the TL-S is a great motor, it's just that the relatively small displacement engine is pushing a somewhat heavyish body, and that takes away some of it's excitement. Nissan learned that lesson with the 2000 Maxima. The VQ30DE-K is their best 3.0 engine, but they needed 3.5 liters to push the bigger body around and still have the low down torquey feeling.
I am quite familiar with this kind of feeling. My last car was a Supra MKIII turbo with no mods. It had 240 hp and 260 lb-ft of TQ, but it's 3600 curb weight really made that motor work hard.
DW
Old Oct 14, 2003 | 02:08 PM
  #48
Kevlo911's Avatar
Kevlo for President
did someone say NA V6
the racing VQ30 http://forums.maxima.org/showpost.ph...2&postcount=27
MmM 415 hp n/a
but in production cars, the 350z is "suppose" to get more hp soon. i have read that nismo got 400hp out the 3.5L vq NA. i don't know if it will be real hp or not ```cough - 02-03max -cough
Old Oct 14, 2003 | 02:29 PM
  #49
dwapenyi's Avatar
My point was that the power to weight ratio just hurt the power numbers. Because my car was a turbo, the TQ curve must have been even fatter than an NA car.Still, the MKIII Supra trubo was the slowest of all the Japanese supercars, like the 300ZX, RX-7, etc. It's weight killed it.
DW
Old Oct 14, 2003 | 08:02 PM
  #50
acidspit86's Avatar
they test with half a tank of gas
Old Oct 14, 2003 | 08:22 PM
  #51
SteVTEC's Avatar
A flat torque curve is nice, but it still needs a lot more torque. The Nissans have it. The Acuras do not. Here is where the extra 300cc of displacement that the Nissan guys have comes in very handy.
Yes, it's definitely a very good engine. The only problem is that it's in a car that's about 200-300 lb too heavy for only 230-ish lb-ft of torque to lug around. Yeah it's fast, but only if you keep it wound up. In that respect it's no different than any other Honda. I have no idea why Acura won't just drop the J35 from the MDX in that **** and stop under-torquing their high-end cars so badly.
Do yourself a favor and search here for "Acura OR CL-S OR TL-S" in thread titles and look at how many zillion multipage locked threads there are. Back when "the plague" infected our forums there was a big Acura-Nissan rivalry but it's died down a lot now that "the plague" has moved on. So anybody that has been here for more than a year or so will be well aware of what the Acuras can do. I expect it to heat up a bit now that the new 04 TL is out to compete with the 04 Maxima.
Hopefully we'll be able to keep it peaceful and intelligent on round 2.
Old Oct 14, 2003 | 08:42 PM
  #52
Big_Ham's Avatar
MaximaFreak
Originally Posted by Craig Mack
Holy crap!
Finally someone posts something interesting.
Mar 12, 2020 12:06 AM
wingnut2006
Sep 19, 2015 06:13 AM
carid
Sep 9, 2015 05:06 AM
coasterswim
Sep 2, 2015 07:43 AM
