265whp....what's wrong with this dyno??
Old Oct 14, 2003 | 02:11 PM
[maxi-overdose]'s Avatar
see the AFR? looks normal if it is a NA car.
but mine's supercharged!
how does the AFR get this high. both of my fuel pumps are working. I see fuel pressure on my gauge and it reads 100+psi at redline. As you can see from the dyno before this, I was getting an 10:1. But now I am getting this messed up flat curve. The only fuel related mod that I add was 1-step colder plugs. I use the copper one instead of the plantium one. Should I switch back to stock heat range?
what's the problem??? please help
Old Oct 14, 2003 | 10:34 PM
lcf's Avatar
lcf
Bump for this kid.
Old Oct 14, 2003 | 11:01 PM
Originally Posted by lcf
Bump for this kid.
lcf
how have you been?
thx for bumping it up for me. I got some good people help me on this issue in the Sc/TC forum. I just want to see if people in general forum can help me.
I am also trying other car/engine forums.
Old Oct 15, 2003 | 08:10 PM
more dyno graph for your viewing pleasure.
1.this is all the lean run I had on Monday. Two runs were cut off due to pinging.
2.2.this is the lean run vs rich run. I ask them to make the window bigger so we can see the AFR better. Seems like both AFR are parallel.
Forge277
Jun 13, 2016 09:26 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
pears
Sep 18, 2015 05:25 AM
