Help 1985 Security System problem
Old Oct 21, 2003 | 10:28 PM
darrenkeele's Avatar
Hello,
I am having a huge problem with the security system on my 1985 nissan maxima. The alarm will go off for no reason and I cannot turn it off except by unhooking the battery. Even after I have unhooked the battery and tried to re-hook it, the alarm is still going off. I read in the manual that I should be able to de-activate the alarm by opening the door or the trunk, but neither work. The last bad thing is that when the alarm is going off the car won't start. I pulled the horn fuse so the horn doesn't randomly blare when the alarm is set off, but starting the car is still a problem. What I did is took out the "indoor lamp" fuse that turns off the security light and for some reason the car starts - BUT ONLY WHEN THE DOOR IS OPEN!??
I really want to sell this thing and think I will be able to get quite a bit more for it if I could start the car with the door closed!
Is there anyone who can tell me how to either fix this problem or de-activate the alarm so the security system will not prevent me from starting the car?
Thank you,
Darren
Old Oct 21, 2003 | 10:59 PM
nubiannupe's Avatar
OG Maxima.org Member
Most of what you're saying isn't quite clear, so bear with me if I go over something that you've gone over already.
Now when you say the alarm, (and this, based on the content in your post), I'm assuming that you're talking about the factory security system, right? And have you tried to de-activate the alarm by opening the door or the trunk WITH THE KEY??
The factory security system is designed to cut fuel delivery (i.e., shut off the fuel pump) when active, which is why you can't start the car when the alarm is going off. That's normal.
The funny thing here is the whole indoor lamp fuse thing you're doing to start the car. I'm suspecting that fuse is directly related to the security system, but I'm not altogether familiar with 1st/2nd gen schematics.
DJLAX152
May 4, 2021 11:46 AM
gustavison
Oct 4, 2015 06:50 PM
carid
Sep 9, 2015 05:06 AM
slowlifer
Sep 8, 2015 05:53 AM
