Reprogramming Keyless entry remotes?
Old Sep 18, 2000 | 04:42 PM
Maximamike's Avatar
Does anyone have the procedure for programming a key thingy for a 95 Maxima? How do you do it? Thanks..
Old Sep 18, 2000 | 05:11 PM
Stillnmax's Avatar
you need all your remotes with you ..
ok if i remember right ... put the key in and out 6 times in a row... then lock the door in the front - so all the doors lock - i used the button not the autolock auto-unlock button- then your lights should flash as if you just locked the car with the remote -{you know how the hazards go off } then take your remotes and hit the lock key with all the remotes ... after your done try the remotes out just to make sure it worked - its kinda long i know ... im almost positive about this... let me know how it goes ... - it might be diff for you cuz i have a 99se - power everything with all the accessories except for the bose and leather - i do have the homelink ... but note that the diff in accessories shouldnt matter - but i thought i should throw it in ....
let me know how it turns out ....
Old Sep 18, 2000 | 08:30 PM
amixam69's Avatar
i talked to the nissan guy about non nissan remotes
he says "nope, need nissan one"
but i've also heard of getting them at ebay ?
i really like the new Jetta Switchblade remote with key.. and if the remote worked on my car.. i would have someone weld my nissan key to it.
any ideas on this ?
Old Sep 18, 2000 | 10:37 PM
GarthG's Avatar
Re: you need all your remotes with you ..
Remember to put the key in the ignition and turn it to ACC before pressing the lock button as it needs to be there to accept the new fob info. I posted pretty much the same response in the 4th gen forum also on how to program more than one.
Old Sep 19, 2000 | 05:13 AM
Stillnmax's Avatar
Re: i talked to the nissan guy about non nissan remotes
any ideas on this ?
of course you need nissan remotes but i was just sayin if he had more than one - i have 3-4 remotes just in case ... just sayin though ...
Old Sep 19, 2000 | 09:12 AM
Maximizd's Avatar
Can I use...
a new 2K remote fob on a 96 Maxima? I 'd like to use a new remote on the used Max I just picked up, the old remote looks like it's seen better days!
Old Sep 19, 2000 | 10:43 AM
Stillnmax's Avatar
dont think so
ask to switch remotes - my salesbro hooked me up with one kuz i asked him - and hes really cool =P
Old Sep 19, 2000 | 12:37 PM
humaras's Avatar
bit confused
about these remotes. By the way--thanks Adidas_Boy for the response on the other thread on the remotes. WHat I am confused about it this: if I have one remote that already works and after I clear the memory by pulling the key out 6 times from the ignition--would I need to reprogram the first (good remote) or I can just reprogram the second one that I want to add?
if anyone can explain this, I'd greatly appreciate it.
Old Sep 19, 2000 | 01:36 PM
GarthG's Avatar
Re: bit confused
Yeah, as when you put the key in the 6 times it clears all past history effectively disabling your security system until you put new remotes on it. So you have to put in all remotes you have when you do this procedure. If you forget one, you have to do it all over again.
And also a 2K remote doesn't work, I tried it on my car already with my mom's remote. Didn't even try to work.
Old Sep 19, 2000 | 02:04 PM
Nick97SE's Avatar
Is that a photoshopped pic or is it real pic of your trunk?
Old Sep 19, 2000 | 03:56 PM
Stillnmax's Avatar
Re: Re: you need all your remotes with you ..
photoshopped and the R was made brighter - it was made smaller --
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
flu2000
Sep 14, 2015 12:34 PM
videomano
Sep 8, 2015 03:28 PM
intimidator
Sep 5, 2015 07:23 PM
Hailstatejig
Sep 2, 2015 06:52 AM
