Why does my rewired clearance light keep burning out?
Old Dec 8, 2003 | 07:35 PM
99MAXSE-L's Avatar
My rewired clearance light keeps on burning out. I have been through 2 sets of aftermarket lights, and ive rewired them so that there are bright all the time to match my HID's.
Is this happening to anyone else? Is there anything i can do that can stop them from burning out???
Old Dec 8, 2003 | 08:28 PM
DanNY's Avatar
Ad·min·is·tra·tor
1. stop buying the cheap bulbs...(90% of the colored bulbs)
2. when you run a bulb that hot 24/7 it will shorten it's life.
Old Dec 8, 2003 | 10:42 PM
BOZOnPJs's Avatar
i clipped the nub instead of rewiring and there haven't been any probs on this end.
are you using a higher wattage bulb than stock? if so, careful you don't burn out your harness.
Old Dec 9, 2003 | 12:44 AM
Maxima 504's Avatar
[QUOTE=BOZOnPJs]i clipped the nub instead of rewiring and there haven't been any probs on this end.QUOTE]
and i bought hypers white and they been in the for almost 6 motns rewired before that the bulbs were in there about a year not wired... i guess im lucky
Old Dec 9, 2003 | 01:50 AM
hakk97se's Avatar
I rewired mine two years ago and have been using the same cheapo (EuroLite) colored bulbs since. No problems. If your wiring is loose and shorting often, you might be blowing your bulbs more frequently. Does it occur on one side more than another?
Old Dec 9, 2003 | 11:50 AM
99MAXSE-L's Avatar
yes it happens on one side more then the other. And no im not using cheap bulbs. However...i dont "Rewire" the bulbs, i just clib the nub and reverse it.
These are the bulbs i have:
http://www.procarparts.com/store-det...%2DXXXX%2DBU2X
1157 12V 27W/8W
Old Dec 9, 2003 | 12:35 PM
ivelweyz
I have $2 Murray's bulbs with clipped nubs for over a year...
Old Dec 9, 2003 | 02:42 PM
99MAXSE-L's Avatar
why is this only happening to me? Are my bulbs more watts then my stock harness can handle or something? whats the deal?
Old Dec 9, 2003 | 05:21 PM
NickStam's Avatar
I've been 'rewired' for 3 yrs w/ autozone bulbs, no problems.
Old Dec 9, 2003 | 05:43 PM
99MAXSE-L's Avatar
Are my aftermarket bulbs overwatted or something? "hyper white" or whatever? whats the deal, the specs are above...
Old Dec 9, 2003 | 06:38 PM
MaxedOut's Avatar
did u buy it from procarparts? it says 1 yr warrenty if they burn out...
but to answer ur questions.. i know we first did it at my house.. i have no idea why its burnign out tho
Old Dec 9, 2003 | 07:02 PM
hakk97se's Avatar
Do you have an aftermarket stereo system? Sounds to me like your electrical system is not stable.. If you are having power surges or drops in voltage, then you will blow bulbs often. Check the leads to your battery and make sure they are clean.. If you have a stereo, considering getting better grounding wires like the new Hyperground kits that are around. All else fails, get a multimeter and watch the power fluctuations.. Most people experience this problem with cheapo colored headlight and foglight bulbs because they are much higher wattage, and thus draw a lot of current, and therefore are more impacted by power irregularities. You might also want to clean the socket itself.
Old Dec 9, 2003 | 07:50 PM
99MAXSE-L's Avatar
yeah procarparts is cool and gave me an extra set for free, but just for now, im using the lower wattage on the bulbs.
Im also experiencing another problem...my blinkers sometimes dont work. Like randomly, this JUST started happening. But now they are currently working, like they it would sometimes work and then sometimes it wouldnt. Yes i do have an aftermarket system. Each of these bulbs last me around like 3-5 months with the higher wattage. Maybe they just blow cuz there on most of the time???
lowpost99
Oct 26, 2025 06:53 PM
Smackasmith
Feb 1, 2016 12:40 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxima30
Sep 7, 2015 06:13 PM
Jamie Bowen
Sep 6, 2015 09:59 PM
