A couple of Maxima questions
Old Mar 4, 2001 | 03:07 PM
I have 2 questions:
1. I recently got a new lock/unlock, etc... remote for my '95 Maxima SE, but I don't have the instructions for programming it. I know that I can take it to the dealer, but I was wondering if anyone can help me do it myself.
2. I was wondering what size bulbs fit in the lights that are next to the headlight.
Thanks for the help, and I'm looking forward to the replys.
Old Mar 4, 2001 | 06:02 PM
black96se's Avatar
REMOTE PROGRAMMING
Each Remote controller has a discreet ID code which must be programmed into the vehicle control unit. The procedures are as follows:
1) Close and lock all the doors.
2) Insert and remove the ignition key from the ignition more than six times within 10 seconds. (The hazard warning lamp will flash twice).
3) Turn the ignition key to the "ACC" position.
4) Push the remote lock button once. The hazard lamp will flash twice to confirm programming.
5) If you need to program additional remotes (up to a total of four), unlock the drivers door using the door lock ****, then lock it again.
6) Push the lock button on the additional remote once. As before, the hazard lamps will flash twice to confirm programming.
7) Steps 5 and 6 must be repeated to program each additional remote.
and the bulbs next to the headlights are size 1157
Lakersallday24
Nov 7, 2024 07:31 PM
halfpol
Oct 17, 2022 12:16 PM
halfpol
Aug 5, 2015 08:24 PM
xUNIxPanther
Aug 5, 2015 09:31 AM
yat70458
Aug 3, 2015 01:16 PM
