Maxima 99 Hi Flow CAT Catalytic Converter
I have a 1999 GLE. I bought a Hi flow CAT Catalytic Converter If I remove the stock catalitic and replace it with the new one which I got recently, will it kill my car or will I get CHECK EIGINE light. What are you suggestions?
The one from EBAY? That costs like $50 or so? It's not even a cat, at least mine wasn't. It's just a metal pipe that takes some power away from your car. I had 3 or 4 different kinds of CATS and they all suck compared to the stock one.
You Cant get a CEL from changing the Cat out due to the fact that their are no sensors post-cat. you could leave everything past the y pipe off completely and your car wouldnt know the difference. Now Your ears definitely would and Im sure the birds and trees would frown on it.
But either way you will see MINIMAL performance increases (most likely nothing on the butt-dyno) and it is very bad for the environment to get a test pipe. If you want a high flow cat just to www.WarpSpeedPerformance.com or www.Cattman.com and stick with one of those - they are environmentally safe but very costly and again provide little to no horsepower/torque gains.
-Cyrus
Originally Posted by chak210
You saing it worthless, but from my own experience my friend changed his intake to K&N intake and he installed Hi flow CAT his car feels more fast from take off
Originally Posted by Big D
Your friend is either drunk or on crack 24/7. A high flow CAT will reduce your low RPM power like MOST of exhaust mods do. I have a y-pipe and a cat-back and the car is WEAKER of the line than when it was stock.
Finkle
09-27-2015 09:53 PM
1992maximase30
08-05-2015 09:27 PM
yat70458
08-03-2015 01:16 PM
