Scratch in side glass? Can it be repaired!? Please help/comment.
On the passenger side front window, I have two scratches in the glass. One is pretty long, but just a surface scuff. The other is shorter but a little deeper. I’ve already called those glass magic/repair people, but they only fix windshields, as it’s a different type of glass. Typically these place only fix the pits/chips, minor cracks and those star cracks on your windsheild.
The only other recommendation I got was rubbing compound, but I don’t know if this will make it worse then better on glass? Please advise, its very annoying on my new car and hate to replace the window just because I’m **** about stuff like that
It really depends... If it's just a surface scratch or scuff, very shallow, you can probably buff it out. Get a coarse window polish, I really like the Zaino window cleaner. Make sure you use a mild abrasive designed for glass. It's worth a shot at least. If it's too deep to buff out, well, your best bet is just getting a new window. With some patience and tools, you can probably install a door window yourself. If you're lucky, you might even be able to get a window from a junkyard but that would probably be pretty hard to find. You can't really do much to repair long scratches, and they'll just get worse over time.
03VQMAX
Nov 10, 2015 03:39 PM
