Last Min Tips bout racing
Old Sep 21, 2000 | 12:24 PM
tunedup's Avatar
I was suppose to run a 325 last week but it was raining
so were doin it tomorrow
he is Stick I am Auto (95 max)
were both bone stock .... cept for me i just got a K&n air Filter
the way i c this is i need to have a really good jump so i cna keep withhim
can someomne tell me what gr i should start on 1 , 2 ,D ?
and how high i shuld rev then let go of break.
Also what is the strongest gear for the ma x... ???
ANY TIPS WOULD B APPRECIATED
Old Sep 21, 2000 | 12:35 PM
ZuMBLe's Avatar
Where you rev to really depends on how good your tires are..
As a general rule you want to brake torque to above 1500. I would go to 1700 or so.. take the car outta O/D.. Orange light on. Put the car into 1st.. Brake torque. When its time to go.. you want to put the pedal down about 3/5ths of the way down..the tires will spin.. when you start moving floor it.. That should be like 1 sec later. Watch the tach.. Shift at or a tick above redline. The tach isn't accurate up there. So shift late. Push the shifter into 2nd at a bit past redline. Keep it floored.. Never take your foot off the gas. Just push the shifter up. Redline 2nd.. same thing.. shift into D... If the race is still on after D (3rd gear) which is shouldn't be... because 3rd tops out at about 120!!! =P if it does go that far.. press the O/D Button to shift into 4th. I think the strongest gears are the first two gears.. 3rd is only okay.. Just keep it floored man. You wanna win don't you? =) Good luck.. =) If you have good tires.. or aftermarket rims with bigger tires than stock.. rev higher.. tell us how it goes..
ZuM
Old Sep 21, 2000 | 01:42 PM
tunedup's Avatar
thnx alot man ...
I gotta win this race...
all this kid does is talk **** ..
and he was thrashin the maxes... so i said i might as well try
plus we got a bill ridin on this
Im ridin stock rims ... dont got the dough yet..
wrapped with Michelin mx4 or some ****
jmlee44
Oct 2, 2022 02:13 PM
gigabyte
Jan 6, 2017 06:05 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
Lilfatz301
Sep 18, 2015 08:06 AM
MplsMadMan
Sep 11, 2015 07:54 AM
