Trunk release broke....why?
Well today I tried to pop the trunk and while I heard to normal noise it makes when it unlocks the trunk, the trunk didn't unlock. The trunk was working fine last night...what could have happened? Is there anything I could check before I take it to a mechanic? Is there any way I can manually open the trunk?
Thanks guys.
Thanks guys.
If and if there's a little lever on the lock or latch that allows you to disable the electric poper, it may have been inadvertently flipped to not allow the electric popper to unlock... much like a valet key and lock levers on the 5th gens... you know what I mean? so the truck can't be opened with the popper even though it's making the popping sound
Thanks guys.
Thanks guys.
Well how can I access the switch? The trunk is obviously locked, and I'm pretty sure my key doesn't work in the trunk lock. What do I do now?
If the key won't work then your going to have to remove the back seat and the metal plate behind that to access the lock to release the trunk. I had to do this a couple weeks ago.
Just took these, my finger is pointing to the lever I'm talking about. It moves up or down and allows you to disable (the mechanical mechanism) of the remote release.
This picture is looking down from the top of the trunck
This pic looking from the front of the trunk toward the back...
oh by the way, mine is a 5th gen, I however don't know if the 4th gen are similar
One time I accidentally flipped the lock switch and my trunk key could not open the trunk. I had to ask a neighbor's kid (smart kid) to climb thru the narrow trunk pass through (in the middle of the back seat) to unflip the switch. He did it, and I rewarded him with $20 for his efforts. Now, I have a masking tape over the switch to make sure that I do not accidentally activate it.
OK...great. Like I said, it started working again for a month or so. Then a few days ago it broke again. My key doesn't fit the keyhole back there- so that's ruled out. I can hear the latch click when I press the button, but it doesn't open it. After a while of pushing the release button the clicking noise stops from the back. For a few days if a friend held the trunk up while I pushed the release button it would open, but that doesn't even work any more. I'm very confused, and I don't want to have to take off the back seat. How do I open it from the inside? Thanks guys.
If the release still clicks when you press the button, does your trunck stick to the weatherstiping when you try to pop it? You said a friend had to lift up on the trunck when you pop it to open it. If so, try lubricating the weatherstipping with some silicone or something like that... tire dressing... Mine sticks and it stuck last night and I had to really lift it .
Well for a while it sticking may have been a possibility, but now even if someone is pulling the trunk up, it still doesn't open when I press the button. Can anyone think why my key doesn't work in the trunk keyhole?
That switch I've mentioned before even posted pictures.. it's to keep the trunk from opening by the auto popper. The valet key is a bit shorter and it won't open the glove box or trunk be can open the door and start the car. They key can't activate the switch I don't think.
Now if your "master key" doesn't open the trunk, then that's another story. Did you buy the car brand new? if so, and the trunk never worked from the beginning, then it's a bad or mismatched lock.. but I don't think that's the case or you would have gotten that fixed under warranty. I'm assuming you bought the car used. If so and the lock hasn't worked since you bought it, then the lock could have been replaced and of course the lock core didn't match your master key so of course it won't open. But if either case, the lock stoped turning with your key in it to unlock the trunk, then the core some how went bad. You might have to replace the lock and mechanism and "key" the new core to match the key you have to start the car. It seems like the mechanism may also be bad because you said the trunk sometimes open with the popper and sometimes, like now it doesn't work. I'll assume you know the rest. Have you tried lubricating the key hole?
Sorry I'm out of ideas other than replacement
Go to the mechanic, replace the lock cylinder and get a new cylinder with a matching key. Forget about the remote trunk release lever because that appears to be problematic. You may get a better deal from a locksmith instead of a mechanic. Just my.02.
REDinLV
Aug 15, 2024 12:30 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
rbaker100
Sep 6, 2015 02:46 PM
