Strut Bushings Install w/pics!
Old Mar 29, 2004 | 05:53 PM
metallic97gxe's Avatar
Master Will
After installing my rear KYB Gr-2 struts I noticed a loud clicking noise over every bump as if something was hitting together upon further inspection I found that the nut and washer on top of the strut was hitting together loud metal to metal contact. So I figured my bushings were bad so I ordered from my Nissan dealer some rear upper and lower strut bushings they were $4.25 each
1. upper/top bushing part number: 56217-61L10.
2. lower/bottom bushing part number: 56218-61L10.
One top and one bottom bushing for each side. Here are the install pics I installed both sides in one hour.
This fixed my problem 100%!
http://images.cardomain.com/member_i...31_49_full.jpg
http://images.cardomain.com/member_i...31_52_full.jpg
Old Mar 29, 2004 | 05:58 PM
d_warner's Avatar
Old Timer
Wow. Look at you. No more bump in the night?
Old Mar 29, 2004 | 05:59 PM
NiNe7-Gxe's Avatar
wow this is great stuff. i just delt with the noise whereas you did something about it. oh well im not on maxspeeds any more
Old Mar 29, 2004 | 06:46 PM
ohannon7's Avatar
what does that do again? Does it make the ride softer or less noisy or both? I think i remember someone talkin about cuttin theirs, or was that bumpstops??
Old Mar 29, 2004 | 07:05 PM
Master Will
you are thinking about the bumpstops that are on the dust boots the bushing help w/the ride some and the noises..
Old Mar 29, 2004 | 07:38 PM
Ladzio's Avatar
that's very likely my problem as wel, I have like a clunking noice fron the rear struts. Will pay attantio to bushings when gonna install my maxspeeds and GR2s
Old Mar 30, 2004 | 09:37 AM
nupe500's Avatar
Jedi Knight
NIce will..very informative!
Old Mar 30, 2004 | 09:58 AM
deezo's Avatar
Wow!!! Look at the difference in those bushings. I'll be investing in a set.
Old Mar 30, 2004 | 10:29 AM
gtr_rider's Avatar
192.168.1.1
i know thats not pliers on the strut piston
Old Mar 30, 2004 | 02:51 PM
Master Will
you gotta use something to hold it while you tighten down on the nut...
Old Mar 30, 2004 | 06:08 PM
AllGo's Avatar
The top of the strut has a thick flat area just above the threads that you can hold with some vice grips. Grabbing the strut piston rod like that will mar the ultra polished shaft and over time will chew into the seals of your strut causing premature wear and totally voiding any warranty claim.
Old May 12, 2004 | 06:05 PM
happyricefob's Avatar
V^___^V
hehe...they are only $3.90/piece in CA
Old May 12, 2004 | 06:12 PM
RA030726's Avatar
I'm nutty for Nissans
vise grips on the piston?! Ahh no way dude. Them things are gunna leak real soon. But aside from that, good work on locating the noises. I bought all new rear strut suspention parts so I never had a problem. But my front left spring binds up I think. Time for a upper strut bearing.
Old May 12, 2004 | 08:06 PM
kingrukus's Avatar
no more maxima...
Yeah the vice grips on the piston isn't a good idea. I put the vicegrips on the end flat piece to prevent it from turning.
I love those spring compressors....I wish I had that type to work with when installing springs.
Old May 13, 2004 | 03:38 AM
deezo's Avatar
WERD!!!!!
The top of the piston shaft is the better position for the vise grips or an adjustable wrench.
Either way, last Friday I replace all of the bushing and hardware when I installed my new struts. No noises and I'm happy!
Old May 13, 2004 | 01:48 PM
SamMan23's Avatar
or just breaking loose the nut just a little bit while it's still on the car keeps it from spinning.
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
Starrider
Dec 18, 2015 04:43 AM
dvcamp
Sep 18, 2015 10:17 AM
Johnny9595
Sep 3, 2015 05:18 AM
