Upper intake mod complete *PICS* (56k die)
Old Apr 1, 2004 | 03:07 PM
|Bijan|'s Avatar
UCF Lexus
Modiddy inspired me to do this.
I tooke a piece of 6" long 3" ID pipe, and basically replaced my intake resonator with it. I welded 2 inlets for those vaccum lines to go in place then painted it black.
I can definitly assure you there is a major growl difference at higher RPMs. It sounds mean as hell.
Here is what it looks like:
**JUST FOR DIXIT**
It took me about 15 minutes to do...not bad..and I only spent $3 getting the coupler from Lowe's.
Old Apr 1, 2004 | 03:33 PM
d_warner's Avatar
Old Timer
Welcome to the home made intake club. I've made about 4 or 5 of these for friends.
Old Apr 1, 2004 | 04:18 PM
Ladzio's Avatar
Looking good!
A write up?? plz!
Old Apr 1, 2004 | 04:33 PM
Street Reeper's Avatar
Handsome
Me too, even fitted for a stock box (hacked.)
Old Apr 1, 2004 | 04:38 PM
MaxSpeedSE's Avatar
56K die? Man i got high speed dial up biiiiiaaaatch!
Old Apr 1, 2004 | 04:54 PM
|Bijan|'s Avatar
UCF Lexus
Here you are!
http://www.drwebdesign.com/mymaxima/upperintake.html
Old Apr 1, 2004 | 05:15 PM
hacim105's Avatar
What is this I've never seen it before? What does it do? Is it beneficial? How do you install it?
Old Apr 1, 2004 | 06:11 PM
stephenlc's Avatar
Just a breather filter. Instead of realeasing back a very small amount of oil back into the intake you release it into the atmosphere.
Old Apr 1, 2004 | 06:19 PM
|Bijan|'s Avatar
UCF Lexus
I didnt know oil went thru it
I opened it up and put my finger on it while I reved it up and it seemed like it was sucking in...
Old Apr 1, 2004 | 06:26 PM
acj's Avatar
acj
I did this same mod on my car, except I had to make an adapter plate to connect the MAF sensor to the cone filter. I also left the bottom part of the stock intake under the cone filter.
It does give a great sound....now only if my exhaust sounded that good....
Adam
Old Apr 1, 2004 | 09:20 PM
|Bijan|'s Avatar
UCF Lexus
Yea I need a Y-pipe now...
Old Apr 1, 2004 | 09:40 PM
Chinkzilla's Avatar
you may want to paint it with some kind of rust resistant paint outside and in. my bro did this same mod to his 4runner and has major rust issues a few months later.
good job though! Really good welds, I can see them QUITE well. ever heard of photoshop's resize function?
Old Apr 1, 2004 | 10:10 PM
maximase86's Avatar
I love lamp.
Nice Bijan....I thought you got a 5-speed though???? Either way nice job. After doing that...you could probably make your own y-pipe!
S
Old Apr 2, 2004 | 05:30 AM
BigDogJonx's Avatar
Yea but you aint weld it.....
Old Apr 2, 2004 | 08:48 AM
|Bijan|'s Avatar
UCF Lexus
Uh, yeah I did....
Old Apr 2, 2004 | 10:18 AM
MrGone's Avatar
I was just about to call BS on that welding part. Looked more like a Dixit weld to me......
Old Apr 2, 2004 | 10:23 AM
MrGone's Avatar
Oh yeah, Bijan, why didnt you extend the pipe all the way to the throttle body? That accordian section sucks (when i replaced mine I got rid of a annoying hum at idle, and the car seemed to pull better).
Also just go to Napa and buy 6-8" of 3" truck radiator hose and 4 3" hose clamps. Works soooo much better than those rink-a-dink Home Depot clamps and shouldnt cost more than $10 too.
Old Apr 2, 2004 | 10:37 AM
BigDogJonx's Avatar
Originally Posted by bijan gxe
Uh, yeah I did....
Try resizing the pic instead of posting something that large on the forum, or next time post a link not the image. Look how much it F's up the layout smoky.
What you weld it with then?
Dixit
Old Apr 2, 2004 | 10:59 AM
Cutler's Avatar
you added a ghetto midsection, what's the big deal You still can have 3 cars and kick and lose by 4....JK Good work!
Old Apr 2, 2004 | 12:38 PM
JAY25's Avatar
why not just remove that plastic and go metal all the way across , no better yet why not get one bend and two more 3 ft sections and make your own custom CAI amazing aint it! your around pipes all the time so dont BS me saying that you aint got no cash.
People not to back up this scrub but he does have access to a welder at his job.
Old Apr 2, 2004 | 02:24 PM
|Bijan|'s Avatar
UCF Lexus
I dunno why yall are trippin and sayin I cant weld.
I had the pipe off, drilled 2 holes...1 for the bigger line and 1 for the smaller one. I took the EXISTING smaller plug, and stuck it from the inside out, tacked it...then welded it in place. Same thing with the big one except I didnt go from the inside out.
Doubt me all you want Dixit...
Jay, I dont need a CAI...I'm cool with this.
Old Apr 2, 2004 | 02:26 PM
|Bijan|'s Avatar
UCF Lexus
WTF are you talkin about? MIG -- Lincoln Electric brand...
Old Apr 2, 2004 | 03:31 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Depends.
It's part of the PCV(Positive Crankcase Ventilation) system, which scavenges oily blow-by gases in your crankcase to either be drawn into the intake tract through that breather hole or through the PCV valve.
It draws air in most of the time, however during shutdown hot oily trapped air escapes into your intake tract, through your airbox, and outside. Mostly it just makes a residue on the inside of your intake tube. Instead, now with that breather, it just releases the oily vapor into the hood compartment/environment instead of gunking up your intake/TB/manifold and being combusted.
There are negatives too, but got to go.
Old Apr 2, 2004 | 04:29 PM
sascuderi's Avatar
How loud is this mod? Is it a nice growl like the G35 or Z, or loud and annoying to those around you?? During crusing speed is it loud or just under WOT???
Old Apr 2, 2004 | 06:15 PM
acj's Avatar
acj
Mine is just like this and you can start to hear the growl (from inside the car) at about 2500 rpm...from there once you go WOT it sounds really nice (even better around 3500+), not annoying at all.
I welded mine with a Hobart 135 MIG---not the strongest of welders, but it beats our Lincoln Arc welder...
Old Apr 2, 2004 | 06:30 PM
acj's Avatar
acj
Trying to get my post count up....
thought I would go ahead and post a link to the picture of my intake
be warned, very high-quality picture!!!
http://www.vci.net/files/adamj-intake.JPG
Old Apr 3, 2004 | 10:13 AM
sascuderi's Avatar
Looks nice. I'll have a similar set up by next week in my 2000 I30 when my Berk arrives.
derekinthez
Nov 13, 2022 04:00 PM
220k+ A32
Sep 11, 2015 02:18 AM
markevans999
Sep 10, 2015 04:29 PM
Maxboy23
Sep 9, 2015 10:37 AM
A32goldylocks
Sep 2, 2015 06:39 AM
