Just got my 2004 Slotted and Drilled Rotors in..
Originally Posted by Matt93SE
Just got word back from the rotor guys on all of the parts.. here's the pricing email they sent me for everything...
FYI, this is through iRotors.. (www.irotors.com)
All brake rotors could be ordered cross drilled only, slotted only, or cross drilled/slotted, as well as blanks. The rotors will be zinc plated silver for rust protection.
1989-1999 Maxima Front Brembo - $109/pair
2000-2001 Maxima Front Brembo- $109/pair
2002-2003 Maxima Front BPI- $109/pair
1989-1993 Maxima Rear Brembo- $99/pair
1994-2003 Maxima Rear Brembo- $99/pair
2004 Maxima Front BPI- $159/pair (Powdercoated Black w/ Black Zinc-see the pics at the top of the thread)
Those prices are for slotted, drilled, or S&D. for Blank rotors, you can subtract $20 per pair (fronts or rears. Both would be $40 off)
Shipping costs depends on the zip code. We could drop ship the order or simply send the order directly to you. (meaning me- Matt.. no thanks. I don't want a truckload of rotors. no room in the garage! please drop ship!
This is a substantial price break over their regular prices. look on their website and it shows the fronts at $129 a pair PLUS $25 for zinc plating. so that's roughly $50 off per set (30%!!)- Matt
We also carry a complete line of Axxis Metal Master semi metallic pads and Axxis Ultimate ceramic pads.
Front Axxis Metal Master- $45
Rear Axxis Metal Master- $40
Front Axxis Ultimate- $50
Rear Axxis Ultimate-$45
Shipping is INCLUDED for the prices of the brake pads anywhere in the 48 states.
Complete set of front/rear stainless steel brake lines are available for
1989-2003 Maxima for $85 shipped.
At this point, I don't see much reason in having you guys order this stuff through me. you can go directly through them and have them shipped directly to you. That takes me out of the middleman. less work on my part, less overhead for me, and shorter wait times on getting all your parts. (Shipping rotors from them to me, then me to you at $20 a set is stupid and costs YOU money.). So I'll save you some money and me some headaches by just offering my sources to you.
I'll be glad to answer any more questions you guys have, but that's pretty much it on my end.
)This is a substantial price break over their regular prices. look on their website and it shows the fronts at $129 a pair PLUS $25 for zinc plating. so that's roughly $50 off per set (30%!!)- Matt
All of those parts are through iRotors. Call them and mention the group deal that Matt Blehm set up for Maximas (I don't remember if I mentioned .org specifically to them). just make sure all the prices match up to the ones posted above, and you're good.
Appreciate everything.
no prob. I thought about becoming a dealer and selling through them, but that's just more work for me for $5 a sale and another middleman for you guys trying to get their cut. I'd rather just get out of the way and let them sell their stuff directly.
Any idea if the 5th gen calipers mount with the same bolt pattern as the 4th gens. So maybe a 4th gen could upgrade to the 5th gen caliper for your kit, but still mount to the normal position for us winter drivers who put the 16's back on in the winter?
Rich, I'm almost done. coming soon. VERY soon.
MaxHP, it's possible to convert to the 5th gen calipers, but at that point it would cost just as much (roughly) to go to the 300ZX calipers and have MUCH better braking-- but they won't fit under the same wheels if you're trying to stick with it as a clearance issue.
you'd have to drill out the spindle on the 4th gen to accept a 14mm bolt. 3 and 4 gens use 12mm mounting bolts, and 5+ gens use a 14mm.
SR20DEN, sure.. the Cobra rotors are $60.. but then you have to deal with wheel stud holes not being the proper size, hubcentric rings that can possibly break or rust to your rotor/hub and cause other weird problems. I'm just not a fan of that method. Thus, I designed this kit around a rotor that's meant to fit this hub bore and wheel stud size.. It also offers more spoke clearance over the Cobra rotors, with about 1.5cm difference in offset..
Chinaonnitrous, check with iRotors on the zinc plating options. I received several sets of rotors with it, and some without. don't recall which were which anymore.
why don't they have it on their website???? i really wanted zinc coated rotors and ended up getting the regular blanks from brembo cause the forum was down at the time of my emergency brake job. got all 4 brembos w/ raybestos qs.
Their website isn't updated every day like some of us would like. IIRC, they still don't have the 2004 Maxima applications listed, but they've had the rotors since last fall.
when you don't do your own web posting/hosting/editing/authoring, then it's hard to keep things updated.
Apr 16, 2020 05:15 AM
hayne
Oct 5, 2015 11:53 AM
