Larger Throttle Body
Old Mar 22, 2001 | 11:40 PM
CalsonicSE's Avatar
Does anyone know whether the Pathfinder's VQ35DE throttle body is larger than the VQ30DE's? Has ANYONE actually tried swapping it (dunno...will it fit)?
Old Mar 23, 2001 | 12:02 AM
emax02's Avatar
Why don't you try it out and see,
Then you can tell us if it works or not.
I think if it would work some one whould have done it by now. But I don't think any one has.
Old Mar 23, 2001 | 12:14 AM
Nismo87SE's Avatar
There is an easier way....
Just goto your local dealer and get throttle body gaskets for both. If the bolt pattern is the same then it will swap over. However you will have to port match the intake manifold, which usually means removing it. As far as gains are concerned you probably won't get any more power at the wheels however you should gain better throttle response and fuel economy. Well at least I did when I swapped a 60mm TB (stock is 50mm) in my maxima.
Old Mar 23, 2001 | 06:37 AM
Shingles's Avatar
The missing moderator
Re: There is an easier way....
yeah but remember, the 4th gen already has a pretty big TB.
-Shing
REDinLV
Aug 15, 2024 12:30 AM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 23, 2015 03:38 PM
bumpypickle
Sep 20, 2015 08:22 AM
followthadollar
Sep 13, 2015 09:55 AM
