changing syn oil back to dino oil.
Old Mar 25, 2001 | 04:54 AM
buss95max's Avatar
when i switched to syn oil, i went to jiffy lube.
now i wanna switch back to dino..
is there something i need to buy to clean out the syn oil?
whats it called? price? steps for it?
thxs in advance...
Old Mar 25, 2001 | 04:56 AM
Sprint's Avatar
i heard thats bad... why you switching anyway?
Old Mar 25, 2001 | 05:01 AM
buss95max's Avatar
why would it be bad?
switching back cuz it burns TOO quick.
when i was on dino oil, it lasted longer.
Old Mar 25, 2001 | 05:06 AM
Sprint's Avatar
what oil are you using?
because i usually change my oil ever 6000 miles
Old Mar 25, 2001 | 05:17 AM
buss95max's Avatar
mobil 1
i got 125k miles btw
this ish affecting the wallet.
Old Mar 25, 2001 | 05:33 AM
Sprint's Avatar
i am using mobil 1 also with Nissan OEM filter.. what kind of filter are you using?
i usually pay $26 for 5 bottles and filter.. thats about $6 more than jiffylube so i figure using better oil and better filter i am pretty much paying the same...
are you sure switching back to dino the car isn't going to be still burning oil as fast? maybe something is wrong causing the car to burn oil that fast because as i said.. i usually run up to 6000 miles an oil change no problems..
mobil 1
Old Mar 25, 2001 | 10:01 AM
buss95max's Avatar
im running the setup as u.
nissan oil filter and mobil 1
i switched to syn oil cuz it was suppose to be the ish.
i wasnt sure on what was needed to switch to syn oil, so i just took it to jiffy lube(first time and last). nothing is wrong with my car, cuz the same thing is happening to like 5 of my friends. we all went syn oil and all hate it now. we also all have 115k+ miles on are cars. ive read many times at this forum and honda ones of syn oil burning like theres no tomorrow....
anyway..i still need some advice on how to switch..
Old Mar 25, 2001 | 11:14 AM
brubenstein's Avatar
You can switch back just by changing the oil and the filter. If you wnat to do a flush, probably not a bad idea, STP makes a good one. The problem is that if you are burning oil there is something wrong. If the car smokes when you first start it in the morning, or when you accelerate hard, then it's probably the valve guide seals. Using an engine flush, and then adding something like Marvel Mystery Oil, may clean the varnish off the valve stems so the seals work better. Burning oil can also result in the EGR and PCV valves getting coked up faster, and much greater/faster accumilation of deposits in the throttle body and intake plenum. In any case, keep a very close eye on the oil level, because running low is real bad.
Old Mar 25, 2001 | 11:26 AM
buss95max's Avatar
thxs man.....
i didnt know what to look for..now i know(stp) and filter
white smoke doesnt come out.
and like i said nothing bad is going on.
i took my car a shop and they said "thats the same thing happens to other cars that come in"
im going to flush the syn. oil out..
JRod28
Dec 29, 2023 09:56 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
Maxgig
Aug 18, 2015 09:17 PM
laparka66
Aug 6, 2015 09:36 AM
RealityCheck
Aug 5, 2015 06:18 AM
