made 10 WOT runs on 1st gear last nite...got 174WHP by g-tech pro. yay or nay?
after reading the owner manually carefully... i stayed up till 2 am and hit the nearby empty roads in livermore and made 10 WOT runs on 1st gear. i input 3,150lbs for the car's weight including myself (i only weight 142lbs), the car has full interior with no spare, jack, trash, and whatsoever. (i keep it clean as a daily driver). since the road isn't long enough for me to make 3rd gear pull all the way to redline, i can only do it on first. anyway here are my 10 results from the g-tech pro meter...
1. 170WHP
2. 168WHP
3. 170WHP
4. 171WHP
5. 172WHP
6. 169WHP
7. 171WHP
8. 174WHP
9. 170WHP
10. 171WHP
notice that run # 2 and 8 are both kinda outlier of the data due to various reasons. it seems to me that g-tech pro is fairly accurate. it also consider real life factors such as drag loss, road condition, temperature, etc.
since i only made 139WHP on the dyno w/ ghost 0304 CEL... i don't know if these numbers are trustworthy. right now i have my new KS relocated to nismo14's relocation spot #1 + custom 2.25" b-pipe, and i'm getting a nice +30WHP including drag loss from g-tech pro....i don't know guys....help me out here.
1. 170WHP
2. 168WHP
3. 170WHP
4. 171WHP
5. 172WHP
6. 169WHP
7. 171WHP
8. 174WHP
9. 170WHP
10. 171WHP
Originally Posted by BlueC
I thought dyno runs are usually in 3rd gear? Or is 1st gear what you use with G-tech pro?
-Paul
That and our 3rd is almost a 1:1 gear where 1st is a what 4:1? Also, using NISMO's KS relocation thing is SO stupid, especially when you do 10 WOT runs in a row. Put it back where it can actually do it's job. Why did you spend the $100 on it when you don't even need it with the location you chose for it?
Nay. GTech Pro is good for nothing, especially dynoing your car.
Also, you may be off several per cent with your weight estimate, and that directly affects the power calculation.
Originally Posted by Stephen Max
Well, it's based on sound scientific principles. But you have to know all the variables involved. For instance, the G-tech does not factor in wind resistance. For that reason it is good to do 1st gear runs to keep vehicle speed down. But then you have increased losses due to accelerating the internal rotating parts, especially the flywheel. Losses due to rotary inertia are lessened significantly when doing dyno runs in 3rd gear, and even more in 4th gear. But a 3rd gear pull with the G-tech will involve large aerodynamic power loss. So, the G-tech will always give lower power estimates than a dyno run.
http://www.spectraquest.com/cart/accelerometers2.html
Also, GTech's algorithm for coming up with the final result is unknown. There are a lot of factors that go into this. Even if you use satellite mesaurements to really get a "3rd party" to verify your acceleration, it is difficult. It's well known that GPS acceleration measurements are completely unreliable due to the speed at which you can update measurements from as many as 12+ satellites (3ft accuracy) and problems with dopplar shift when coming up with the calculated measurements.
Check out what professionals are using as a "best approximation" replacement (the VBOX) and you'll see why.
http://www.racelogic.co.uk/vbox/aboutvbox.htm
(Sorry you wasted money Kevin
Originally Posted by happyricefob
thx for all the comments guys... i never expect this thing is a good-buy in the first place. never hurt to try out new stuff u know?
You'd be suprised how much more your car weighs than you think. I was thinking I'd be right at 3050 because of a fair amount of weight reduction but I was at 3120 with 1/2 tank of gas. So, with no gas and the 5Spd in I might break 3K. Sweet. Also. 4th gear is cheating. 4th in a 5Spd is a 1:1. Therefore two sets of teeth are eliminated, thus reducting friction. G-tech might be kinda cool but there is too much possibility for error to judge gain from mods. He!l, look at the numbers you pulled. There is a six HP difference from your best to worst run. Thats the difference of most bolt on mods. So, you could easily fool yourself into thinking that a mod has helped 7HP when infact it barely made 1. Also, why is there no TQ. I would think that we all know that TQ is more important than HP by now.
^It's just like going to a normal dyno. There is ALWAYS a difference between runs. You can go to a dyno and do 10 runs with time between runs for the engine to cool and you'll always have that margin for error.
I wouldn't use the G-tech to measure the power that you have rather than use it as a baseline tool and figure out approximate gains as you mod. Plus, didn't you dyno that one day in Fremont?
I took my Gtech to the 1/4mi one day and it read .3-.4 seconds too fast everytime... Now I hardly even take the thing out.
i've had the g tech pro for a year now and as far as i can see it's pretty accurate but in order for you to get good readings you have to be accurate too in setting that thing up y,x.z dimensions, car weight with you in it , rpm ,and the closer you run to 1/4 mile the more accurate your readings will be cuze it links your average acceleration to your weight and rpm so go and be ready to set it up right once and for all and do it over and over tell you think it's the most accurate specially the weight well and the rpm +xyz lines,,, mine was 6-7 hp lower than the dyno cuze g-tech actually measures the real power that's pushing the car after drag ,wind,elevationand temp but on the dyno you don't have all this,,, and it was .1-.2 faster on the track ib think because it doesn't realize the car started moving immediately but that's .1 second i hope that helped so peace
thx for all the inputs. i knew this thing isn't the best product to get my WHP and 1/4 result. perhaps i was simply looking for a refernece point that's all. anyway i will make couple runs every week at the same spot/time with g-tech and record my results responsibly, and if the margin of error between each runs is minimal, i take that as a good reference data for my car.
The Frye
Sep 2, 2021 11:03 AM
Finkle
Sep 27, 2015 09:53 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
sdotcarter
Sep 2, 2015 09:53 PM
