how much hp do you lose with low compression?
Old Jun 12, 2004 | 06:45 AM
meccanoble's Avatar
Sports Button FTW
i'm getting 140 on my 156k engine. Its very consistent (between 135-140 on each one.) but i'm a little worried that i'm being robbed of the potential i should be at. Some have told me i'm very low and i'm losing a lot of power, others tell me i'm ok as long the numbers are consistent i'm ok. Everyone with good knowledge on this please post your thoughts and tell me if i should replace my engine, how much hp i'm probably losing with the low compression, etc. thanks
At what point/price is it beneficial to start all over again with a newer engine?
Old Jun 12, 2004 | 07:17 PM
meccanoble's Avatar
Sports Button FTW
Bump Ga Dammit!
Old Jun 12, 2004 | 07:18 PM
BigDogJonx's Avatar
Minimum is 142 with no more than 14pisi difference in each cylinder.
You are below that and definetely losing potential power through the band.
Replace it with another engine, at this time of the maxima legacy, the 4th gen engines are available at a dime a dozen.
Dixit
Old Jun 12, 2004 | 08:56 PM
liqidvenom's Avatar
brotherhood of tq
i thought that you need for all the cylinders to read close to one another? but i dont really know so...
Old Jun 12, 2004 | 09:15 PM
Dave B's Avatar
Not DAVEB the parts guy
Consistency is key and from what I've read, testing with a warm motor is the correct way of doing it. On a cold motor the numbers may be slightly lower.
Dave
BigDogJonx's Avatar
What part of no more than a 14psi difference between any cylinders did you miss?
He said they were all in the 135-140 range.
Old Jun 12, 2004 | 09:35 PM
araffio's Avatar
Sell the car and get something new....that's what I'm doing...STi
-Tony
Old Jun 12, 2004 | 10:37 PM
meccanoble's Avatar
Sports Button FTW
my friend that helped me with compression just bought a new kit and did compression and got 30 more pressure than before. He's going to help me do compression again. If its 140 and u guys really feel that 140 is too low, i may get engine replaced with tranny....
Old Jun 13, 2004 | 04:06 AM
CandiMan's Avatar
Say Candyman 5 times
Let me ask you this, how does the engine feel? Does it still feel nice and strong like it has the past few years? As you know consistency is the key, but along with consistency you don't want to drop below the minimum. I would think if you were below the minnimum it will also be associated with a power problem. If you're NOT having any driveability/power problems why change the motor regardless of what readings you're getting.
Here are my suggestions
1)Put the car on a chassis dyno and see what you're getting at the wheels. If the numbers show no significant power lost thru-out the power band pay your dyno bill and enjoy your car for many years to come.
2)Dyno pulls cost a lot less than parts/labor for a engine change.
3)If you're still concerned about your compression readings find someone who can do a leak down test.
4)The problem with doing only a compression test is that they're too many varibles that can effect your readings, as you're finding the different gauges you're using
5)A leak down test takes more time but if along with compression test you will definately know how efficient your cylinders and combustion chambers are.
MIKE
Old Jun 13, 2004 | 07:37 AM
Dave B's Avatar
MIKE
Listen to this guy
aw11power
Oct 10, 2021 04:57 AM
gigabyte
Jan 6, 2017 06:05 PM
sliptap
Sep 30, 2015 05:57 AM
