1993 Maxima Pressure hose installation
Sup guys. i need some advice. i recently sprung a new leak of powersteering fluid from the high pressure hose. Its leaking pretty vigorously and I need to get it changed soon. I was wondering if this is a job i can do on my own or do i need to take it to the shop. What kinda tools do I need? This maybe a stupid question and is probably a 15 min job, but im a newbie at this. Thanks
it's pretty easy. You'll need a big wrench or big socket - 24mm I believe. Just undo the bolt holding the bottom end of the hose to the pump and let the fluid drain out. Then undo the top by the strut tower. Put new hose in place and use new copper washers (should come with the new hose) and tighten it down. Refill fluid.
thanks
the headlights are from a 3 series BMW - check out www.geocities.com/bmwconversion
lots more pics of my car at http://maxima.cardomain.com/id/craigbrace
good luck
good luck
thanks
good luck
good luck
thanks again man.
SmokinMax02
18
Sep 11, 2015 12:25 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
altome15
Aug 10, 2015 07:05 PM
