Yes, I finally can get some suspension travel back with these!!
You pretty much get everything you ever want in a strut/spring. Adjustable height, full suspension travel, adjustable damping and camber adjustment.
Originally Posted by hacim105
So from the information I've gathered, if you wanted you could put these on your car and you could decide not to lower it at all? If so, that is crazy. I may just have to buy these, they look pretty sweet. Tell us how the install goes.
1MAX2NV: I thought you were getting KSports?
Also, I think these D2's are somehow rebadged by D2 Auto Technik. Check their website and compare logos: http://www.d2technik.com/home.htm
so
So one question are these like the JIC where as you can lower the strut body on the perch so that you will lower the car but not loose any suspension travel? The one thing the JIC have over all other is that but if the D2's have that than Im deffinately going with them.
Bruce
Bruce
Get them installed yet? Lets see some pics of the car with these coilovers installed. I am actually interested in this setup, this should fix my camber problem, my Eibachs/Tokico[blue] setup is getting old now too. Hows the ride? Is it too stiff?
1MAX2NV - How much camber adjustment is there in the plates 1.0 or 2.0 degrees or more. Just wonder cause for track purposes some negative camber is good and I was hopeing these had some decent adjustability when it comes to camber.
Thanks,
Bruce
Thanks,
Bruce
Ksports are rebadged D2s. Different color and logo but still the same. Anyway, Ksports decided not to carry A32 application because lack of pre-order. I paid and waited for 2 months. I believe D2 Technik and D2 Racing are not affiliated.
Bruce...the camber plates look the same as the Stillen. What really hold maxima's camber plate adjustablity is the size of the strut mount hole. You can only move it so much. I'm just interested in getting the camber back to OEM spec.
Thanks,
Bruce
Thanks,
Bruce
Bruce
The question would be if they are willing to deal with camber plates??
Originally Posted by Ludacris
Do any of the socal guys know if this D2 is affiliated with the D2 place in Alhambra?
sexy coilovers dude..
oh, and the company website www.d2racing.com.tw
Hey thanks, that makes sense now that I think about it. But I know what you mean I have 1.5 degrees negaitive camber and Im tired of running through ties all the time.
Bruce
Bruce
Hey Bejay,
Thanks thats good to know but for road racing I dont go more than -2.0 deg of camber cause my turn in start to get to quick and I have to way to finese the searing and also I find my car lags on the straights cause of the camber.
Bruce
Bruce
Hey Bejay,
Bruce
Bruce
Originally Posted by BEJAY1
Good point. That's the problem with either very low profile tires or too much negative camber. Slower accel and longer braking distance.
Bruce
But My suspension is to still sometimes, I need better dampening. I bounce way to much, I have tried adjusing my rebound but with 550/650lb springs the illuminas just dont seem to keep up. Thus, Im switching to either these D2's or JIC's.
Bruce
Bruce
Even with different dampening you're still gonna have some bounce. 650's in the rear = over 3.0cps (cycles). Anything but a glass smooth track is gonna bounce at that stiffness.
But thanks for the input I like to hear how other people think and what they see as good and bad. Helps me make a decisions on what to do with my car.
Thanks,
Bruce
Not to mention I am killing my CV's. Does anyone know where I can get high hp/tq Axels.
I have heard good things. I know ceasar has some since he is on their web page.
Well yeah I know, thats why Im switching to JIC's cause there spring rate is a little more appropriate for the street not to mention that they have adjustable perch's so I can effectively lower the vehicle with out changing the ammount of suspension travel. See thats really my problem. Im so low that its changing the effictive rebound rate of the shock and its causing me to become unstable when cornering and hitting anykind of hole or bump. So I dont like the idea of the car being so off balance. So Im going to a more adjustable suspension.
Thanks,
Bruce
Thanks,
Bruce
Originally Posted by Iilac
On the D2's, the height is adjusted on the bottom, so full suspension travel is retained.
Bruce
laparka66
Aug 6, 2015 09:36 AM
