Front pass. axles, manual and automatic.....help
Old Oct 7, 2004 | 12:44 AM
NISMOPower's Avatar
Hey everyone, i'm in the middle of a 5spd conversion. I had bought a reman axle from autozone because my automatic passenger side boot was but wide open. Well, I started to bolt up the axle to the hub with the axle nut, i noticed that the diameter of the end shaft was smaller than the auto. The shaft can fit loosely through the original axle nut. Is there a difference in the manual and automatic axle diameter? The axle came with a different axle nut but i want to make sure i have the correct axle. length wise it looks identical to the auto one i had only difference is that diameter of the end where i need to put the axle nut on.......
Chris
Old Oct 7, 2004 | 03:51 AM
njmaxseltd's Avatar
Chris
Yes, I believe you need an axel for a manual tranny.
Old Oct 7, 2004 | 12:39 PM
NISMOPower's Avatar
Well i did get a manual axle that i ordered from autozone, but the thing was that the axle seemed to fit perfectly fine. the only thing i saw was that the threads where the end of the shaft is, is a smaller diameter than the original auto axle. Does any info on this???
Chris
boomerbrian
Nov 8, 2015 05:10 PM
kingw323
20
Oct 21, 2015 08:36 AM
Starrider
Sep 17, 2015 07:26 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
AT978
Aug 15, 2015 06:39 PM
