Help me install my springs....
can anyone give me a link or give me directions on how to swap my springs out? also, im planning on puting Intrax on and it's said that the rears sag a little. is there anything i can put before or after the spring to give it a little extra .5 inch boost? thanks
o yeah, does anyone know if they are progressive? if they are, can i cut a little off the front spings to level it a little? thanks again
thats kool, i probably wont be getting them for a week or so either.
but does anyone know if they are progressive so i can cut them or not? thanks
Originally posted by NickStam
If you feel like waiting I'll have my directions done in a week or so.
right now, im going to use http://integra.vtec.net/geeser/megamax/springs.html as reference to my spring install. so far it seems clear but its only for the front spring install. it seems that it would be the same for the rears but how do i get to the bolts on top of the shock towers for the rear? thanks
they are in the trunk .. you have to pull away the panels and you will see black rubber things on both sides.. the bolts are located under them.. actually the rear can be worse than the front because sometimes the bolt on the rear gets messed up..
go to a borders or barnes and noble and read a Manual for about an hour.. take notes if you have to..
can anyone else get into this site? im not able to for some reason.
Originally posted by SprintMax
http://www.c-com.net/~scutchen/Car%2...ma_springs.htm
MaxLife17
Jun 27, 2019 01:37 PM
