Where to find H3 Wiring Harness
Old Oct 21, 2004 | 03:07 PM
Nathan's Avatar
Just wondering if you guys know if there's such thing as an upgraded wiring harness for H3 bulbs? I just bought a set of Narva Rally Gold 85watt bulbs and was thinking it might be a good idea to change the wiring harness. Thanks
Nathan
Old Oct 21, 2004 | 03:26 PM
Y2KSESteve's Avatar
As far as I know there are no harnesses available for H3 bulbs..
Old Oct 21, 2004 | 03:38 PM
MaxedOutR34's Avatar
I think SPW does, but I am not positive.
Old Oct 21, 2004 | 03:48 PM
Y2KSESteve's Avatar
They carry Nokya Harnesses and the H3 is not available.
Old Oct 21, 2004 | 07:38 PM
Scope's Avatar
Im izz sexay
You might have to try the art of buying a cheap set of h3 fog lamps with harnesses and use that harness. Ebay comes in handy when you need this.
Old Oct 21, 2004 | 08:12 PM
ny96max's Avatar
you could make your own by using a relay and some 16-14 gauge wire. But i think the only problem you might have will be with the lenses cracking due to the high heat of the bulbs, specially in the winter time. Never heard of anyone burining out their wiring for fogs, but maybe im wrong.
Ant
Old Oct 21, 2004 | 09:53 PM
Nathan's Avatar
Thanks guys. Actually the company I work for sells SPW products but yeah they dont make the H3 harness. I think what I'll end up doing is buying some high quality wiring from my friend that owns an audio shop and use that. Although I might be able to get away with using the existing wiring since its wired into Hella foglights and wiring.
Old Oct 22, 2004 | 09:12 AM
gto400no1's Avatar
i have not found any, also i have been told it is not a good idea to upgrade the fog lights to a higher wattage because the heat can cause the glass on the fog light to crack... just my $0.02.
PH98I30
29
Feb 10, 2025 12:03 PM
The Frye
Sep 2, 2021 11:03 AM
dvcamp
Sep 18, 2015 10:17 AM
doctorpullit
Sep 10, 2015 06:33 PM
crazyespn
Sep 3, 2015 01:30 PM
