Yellow Fog light bulbs (hella yellowstar)
I don't really use my fog lights a lot. I mostly use them in bad weather or fog. I'm intrested in some yellow bulbs for when I do use them. I heard yellow light cuts through the fog better and makes you more visible to other drivers compared to regular white bulbs. Has anyone had any experience with these hella yellowstars: http://www.rallylights.com/hella/H3.asp
Thanks in advance
Thanks in advance
there is a website (don't remember the url) guys over there make your stock fogs look like the lexus ones. some time ago i wanted to put yellow bulbs too, but after looking at several pictures of the light output of different yellow bulbs, i decided not too.
and no, on sig. thats the regular bulbs (or maybe i did that in photoshop. hids are photoshop done)
Thanks a lot for searching. I think I'll go ahead and get them. It doesn't look that bad to me. I'm more for functionality rather than looks anyways. Can't go wrong with $12 for a pair. I'll order them with the Hella Supertone horns.
Thanks for the help
If anyone has more input, feel free to post.
Thanks for the helpIf anyone has more input, feel free to post.
I have hella yellow 85 watt fogs in my car and they are not nearly as yellow as I had hoped.
The headlights are XD5, as is the foglight on the left. The Hella bulb is on the right. It looks more yellow because of the contrast with the "super white" XD5s, but they aren't that yellow.
I have yellow factory fogs on my QX4 and they are really good in the fog/snow. They are also significantly more yellow than the Hella bulbs I bought. The Hellas are brighter, though because they are 85 watts.
I'm convinced I'll go with them. Sure they're not as yellow as I would hope, but they're more yellow than with regular bulbs. I do have silverstars for the headlights so there will be some contrast. I don't think I would like the look of my car with yellow film on the fog lights. In bad weather I really won't care what they look like. Thanks everyone
Just to add... I have PIAA Ion Crystal Yellows and they're nice.... wish I had some good pics to show ya but I don't. I think they work great in bad weather with my HIDs, which tend to get too "reflective" in misty rain and fog....
I think most importantly, your fogs should be focused at the correct level. Its been argued (I've done some Google research on this) that the color doesn't make that big of an impact, unless you're in snow, then yellow does help. Whether white or yellow, fog lights should be low and focused on the road, so that there is minimal reflection off the fog and rain "particles" back to your eyes, like the low beams do.
Here is something I found in a lighting guide at www.tirerack.com about the "ideal" fog light beam height:
"Typically, fog lights are mounted under the front bumper about 10 to 24 inches from the ground. There are two important issues to address when installing fog lights, the first is to minimize the amount of glare that returns to the driver's eyes, and the other is to minimize glare into oncoming driver's eyes. Both must be accomplished while putting as much light as possible on the road.
Park the vehicle 25 feet from a wall on a level surface. Measure the distance between the center of the auxiliary light and the ground. Place a horizontal mark on the wall at that height.
Visual aim is made with the top of the fog light beam 4 inches below the lamp center at 25 feet with the lamp facing straight forward."
You mentioned tirerack so I went over there and decided to read up. I noticed this:
"While auxiliary fog lights have traditionally been available with clear or amber lenses, the amber lens fog light is losing popularity because it has not proven to be more beneficial in foul weather than clear lens fog lights, is not as effective as a clear weather cornering light, and is often less complementary to vehicle styling."
So I guess maybe I won't gain anything from the upgrade to yellow bulbs.
Also some info here: http://www.newton.dep.anl.gov/askasc...9/phy99xx4.htm
I'll stick with what I have now, thanks for your input
The Frye
Sep 2, 2021 11:03 AM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
its a look into the very near future, im not looking forward too. god damn snow
