Hella air horns
I got the triple Hella airhorns.
They're louder, although a little bit more high-pitched than the stock.
I got it for $45 shipped.
And the install isn't too hard. You just have to get a little bit creative about how you put them in. I went to Home Depot and got some brackets, but they aren't stainless steel and are going to rust come winter. I have to redo them.
The wiring is easy, the figuring out how to fit the airhorns in is a little tough. The most painful part is bending over to put them in. I spent a good 8 hours bent over my car and my back killed me the next day.
http://www.rallylights.com/hella/horns.asp
And attached is a picture of the horns.
This is the top view.
similiar pics
Originally posted by Riot^
ok, I know some people installed these.
What exactly is dofferent, how much were they, and was the install difficult?
Thanx
Thanx
http://integra.vtec.net/geeser/megamax/horns.html
Just make sure to use the relay.
Originally posted by Ravq
Here are some really good installation instructions from one of the members of this board
Originally posted by clee130
Side view.
Side view.
they aren't nearly as loud as they couild be.
No problems yet. And how'd you fit the horns back there?
Originally posted by ngthing
have you had any problems with the horns being so close to the engine block? my horns are in the far right hand corner near my hood spring things
you can sorta see in the pic. where did you mount your compressor?
I mounted my compressor in between the where you pour in the window washer fluid and the anti-freeze tank.
I was really paranoid that it would get wet when it rained. But it rained last night and after I drove it and got home, it wasn't wet at all.
And just for future reference, you can't link pictures from Geocities.
built a little mounting bracket, it was close. i have a 3rd gen.
You can get a rough estimate from my pics, but it's not that big.
But I've seen some other brands where it's pretty big. The Hella ones are not that big.
It's not that hard to wire if you've done other wiring before. The compressor wires to a ground and to the relay. The relay wires to a ground, the battery, the stock horn, and to the compressor.
Originally posted by Pervis Anathema
How big is the compressor? How hard is it to wire into your electrical system?
tarun900
19
Dec 20, 2021 06:57 PM
