Full 3.5 running (4th gen)
Old Jan 23, 2005 | 01:03 PM
  #81
finny's Avatar
good work tilley, i gotta take a ride down that way and check it out sometime
Old Jan 23, 2005 | 01:47 PM
  #82
TILLEYS99's Avatar
Lives in a 11sec maxima
Are you nearby? Maybe you can get a swap
Old Jan 24, 2005 | 06:33 AM
  #83
Maximized Jiggs's Avatar
So you have done two engine swaps and they are both working without problems right? If I get the swap done through you and something happens, you are 2 to 3 hours way so that would be a problem.
Old Jan 24, 2005 | 09:13 AM
  #84
HenryNYC1's Avatar
Originally Posted by MaXiMa 3.5 SE-M
Wow yeah thats cool, I hab a 96 Maxima with a custom geared 5speed. I took Actually my VQ35 frum a 03 Pathfinder. It was my uncles and a tree fell on it, and it was totalled, so i took his engine and ....took it apart(the engine wasnt damaged) i took it 2 my shop and lightened and shaved the crank, got high revable rods frum my brother shop, DUNK Performance Thailand, and other goodiees. I used a kit to bring up oil pressure,volume, since i wanted 2 rev higher, changed out the stock water pump for a more performance oriented one, and new timing chains and dampers and tensioner, ported and planned the heads and put new oil vained rods. Bought up the compression to 11.15:1, new gaskets and head bolts and headers, engine oild cooler and bigger radiator with slimmer fans. Sounds costlly , yeah but actually it wasnt. Also i wanted to fabricate a mounting plate to put the 300ZX dual throttle intake manifold but , the clearance wasnt waut i wanted, so i custom bent and fabricated , my own high volume upper manny with 2 throttle bodies, one for frunt 3 cylinders and 1 for the rear 3 cylinders.using the stock TPS ish no prob and few mods for the IACV is needed , the onlee thing was now i had 2 intake throttle bodies and onlee 1 MAFM(mass air flow meter. well since i was going to modiffy the programming of my computer, i basically got the computer to interpuret the reading frum the air meter as doubled, to acknowledge the right air intake.Besides that tho i reused alt and comp brackets frum my VQ30 engine and such accesories like that i basically used frum my old engine. Oo pics are soon 2 be displayed. The big test was can the tranny handle it? Well i had beffed it up with stuff i got or had lying around frum a wrecked 02 SE(engine frunt cover ect smashed) It did for the Dyno which turned a 287.45 HP @ 7100RPM the wheels(All Import Dyno Testers) and 278 lbs TQ. Hmm we figured a better of 300 hp if just @ engine, i was kinda upset i guessed 4 more HP, but ill just go bak and tinkle wif my ECU programming, but 4 sum reason my 3rd gear seems to hab stripped out. It NO LONGER WERKS!!, Wuts this, well i am using a slightlly beefed up 3.0 SE tranny. Wut should i do?????
I are the confuzed.
Old Jan 24, 2005 | 09:50 AM
  #85
Pimpmobile's Avatar
my maxima runs 8s and puts down 400whp NA OHH YAAAA VEEEEEEE-TECHHHH oh.. wrong forum
Old Jan 24, 2005 | 11:16 AM
  #86
tpduke112's Avatar
I thought pics were coming like 2 days ago of the pathfinder vq powered Max. I WILL NOT REST UNTIL I SEE PICS!!!!!!!!!!!!!!!!!!!
vybz05
Dec 10, 2015 07:38 PM
maxinout93
Oct 27, 2015 01:29 PM
Finkle
Sep 27, 2015 09:53 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Blackwind
Aug 5, 2015 06:35 PM
