Pulling out engine/tranny...where should i mount the hooks?
Old Jan 21, 2005 | 11:10 AM
nismology's Avatar
Just like the title says...thanks in advance...
Old Jan 21, 2005 | 12:06 PM
nismology's Avatar
Bump...i was thinking of lifting it by running the straps underneath the lower intake manifold? You think it can handle the weight of the engine/tranny??
Old Jan 21, 2005 | 12:10 PM
s0ber's Avatar
lift it by the intake manifold.. k thx
Old Jan 21, 2005 | 12:13 PM
nismology's Avatar
Old Jan 21, 2005 | 12:15 PM
s0ber's Avatar
mzmtg's Avatar
Minister of Silly Walks
Bring the engine and trans out from below if you have a lift.
Old Jan 21, 2005 | 12:19 PM
s0ber's Avatar
No lift, would be easier tho =D
nismology's Avatar
Hmmm. I wonder if i could use the engine hoist to lower the engine to the ground first, then use it to lift the front of the car up high enough??...
Old Jan 21, 2005 | 12:20 PM
s0ber's Avatar
Old Jan 21, 2005 | 12:26 PM
nismology's Avatar
Originally Posted by s0ber
Shush ****. Go play in traffic or something...
Old Jan 21, 2005 | 02:02 PM
nismology's Avatar
Lowering the engine/tranny out of the car isn't an option, unfortunately...
Old Jan 21, 2005 | 07:37 PM
Nismo3112's Avatar
Custom User Title
Im guessing mount the hooks at the engine mounts?
Old Jan 21, 2005 | 07:52 PM
deezo's Avatar
Thing is it'll come out of the top but you'll have to finagle it and work slowly. The engine should come out from the bottom but many people have removed it from the top.
Old Jan 21, 2005 | 09:35 PM
Nismo3112's Avatar
Custom User Title
Engine+tranny at one time? From the top?
Old Jan 22, 2005 | 12:35 PM
nismology's Avatar
Hmmm...I was wondering why the hooks should go since im lifting it out. Im running two straps underneath the lower intake manifold already. I'm going to use a chain as well but need to know exactly where the hooks should. I was thinking maybe the EGR pipe coming from the exhaust manifold could be used as well as the transmission mount on the right side of the engine bay. Sound like a good idea??
Old Jan 22, 2005 | 07:33 PM
Broaner's Avatar
2060lbs and falling...
I don't think the engine and tranny will come out the top if they are still matted(Definitely not if auto). I connected the cherry picker chains to the LIM. I used the two studs in the LIM with big @ss washers and the OEM UIM bolts. It worked fine and the LIM didn't do any complaining. The rope is just there as precaution.
Old Jan 22, 2005 | 08:26 PM
nismology's Avatar
Why wouldn't they be able to come out as one unit? I understand the whole assembly will rock to the side as it's lifted out but i dont see why it couldn't be done.
Old Jan 23, 2005 | 05:31 PM
Broaner's Avatar
The frame rails are too close. It isn't wide enough to get them out together without a lot of frustration.
Old Jan 24, 2005 | 11:55 PM
jcy98maxse's Avatar
Turbo is too much fun!
I've taken mine out with the one hooked to the motor mount and the other to a starter bolt. Thats with the tranny taken out already. Was gonna pull it all together but I think there was someting in the way. My buddy pulled his out together with no problems but he has no ABS which if I remember right there was a module that sits by the intake that made it a lot more difficult for me to pull the motor and trans together. Both of us took the hood off too so we didn't have any cherry picker clearance.
However, I did put the tran and motor in together but I had to angle the motor at a really steep angle to clear. take some work but can be done. Good Luck.
Old Jan 25, 2005 | 12:34 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
The two points that worked well for me are the passenger side MOTOR MOUNT *yes broanar lol* and then the topmost bolt hole that goes through the tranny. I just stuck a bolt through a few chain links and tightened her down.
Old Jan 25, 2005 | 12:56 PM
nismology's Avatar
Appreciate the replies. I just figured out for myself yesterday that the tranny has to be removed beforehand. The crank pulley wouldn't clear the frame when i was trying to remove it. So blah blah blah....off comes the tranny then i'll remove the engine from the top. I routed 2 towing straps around the lower IM and they're rated at over 900 lbs. combined so i have some headroom as far as that is concerned.
Old Jan 25, 2005 | 01:30 PM
Larrio's Avatar
The Definitive AE Master
nissan sells a specific bracket that can bolt into your block to pull the engine out from the top. At the rear of the engine there is already a bracket pointed upwards that you can bolt that to, as for the front I am unsure of the location
Old Jan 25, 2005 | 05:52 PM
Broaner's Avatar
Seems stupid to buy the part when there is a proven method to get it out. That'll be at least $45. And that is $45 wasted.
Old Jan 26, 2005 | 07:22 AM
nismology's Avatar
The LIM is working fine...
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
sliptap
Sep 30, 2015 05:57 AM
