350z Sport Horn vs. 350z Stock Horn
Old Feb 2, 2005 | 01:52 PM
UGAd13's Avatar
Does anyone know if the 350z Sport Horn (here) sounds different from the stock 350z Horn? I looked on Ebay and some descriptions of the sport horn say, "Do you want your Z to sound different." Well, I want the horns that sound like the stock Z, deeper than our ones. Jerry Rome has stock Z horns for about $90 for the set (high and low) opposed to $45 for the "sport horn" set. Also, I don't want the hella horns so please don't suggest those. Thanks and any info is appreciated.
Old Feb 2, 2005 | 02:03 PM
Kevlo911's Avatar
Kevlo for President
Hmm, I want to know too. If these sound good(I don't think you can get worse than stock 4th gen) Ima buy some. Not a bad price IMO.
Old Feb 2, 2005 | 02:06 PM
Nismo3112's Avatar
Custom User Title
Someone get a sound clip!!
Old Feb 3, 2005 | 02:19 PM
Kevlo911's Avatar
Kevlo for President
http://www.performancenissanparts.co...roducts_id=192
Sounds okay, not as good as stock 350z according to 350z forums, but different. So ima buy pretty soon. It sounds way better than stock 4th gen..
Old Feb 3, 2005 | 03:54 PM
4x4Max's Avatar
i dont like it, too high
get a semi horn on it
would it be hard/expensive to install one of those?(serious question)
Old Feb 4, 2005 | 06:02 AM
UGAd13's Avatar
Thanks guys. I think the sport horn is too high compared to the stock Z horn. I've heard the stock Z horn in person and really like the sound of it. Guess I have to fork over some extra $.
Old Feb 4, 2005 | 03:34 PM
Dave2112's Avatar
I got a horn off a 2004 Range Rover the other day. I got it free, and don't even know if it'll fit/adapt, but its worth a shot..
Old Feb 4, 2005 | 04:03 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Yes, very. Those horns have the utility of a compressed air tank to feed to horns from. In theory, you could hook one up to a max in which the air compressor tank was placed in the trunk and the horns under chassis. It's the ONLY way to get big sound. I have FIAMM air horns which put out 134dB...while that may sound like alot, the frequency is what really matters...
Because my car now sounds like I have a 134dB clown horn
Old Feb 4, 2005 | 06:34 PM
Slider's Avatar
It should, depends on how the stock system is set up. There's two types
1.) The horn is grounded and the power is switched, these usually have 1 wire coming from them (the positive) and the it's grounded to the mounting bolt.
2.)The horn has constant power and the ground is switched, these usually have 2 wires coming from them
Stock is the 1st one I believe, and if the range rover is the 1st one also it should be no problem. If they're different you would have to run a relay, which wouldn't be too hard either.
Old Feb 4, 2005 | 07:34 PM
konak85's Avatar
I heard 350Z horns unleash 10 horsepower at the crank.
Old Feb 4, 2005 | 10:29 PM
EdL97SE's Avatar
Anyone know if the 350Z Sport Horns are plug and play on a 4th Gen?
Thanks.
Old Feb 6, 2005 | 02:04 PM
Kevlo911's Avatar
Kevlo for President
I heard you were
No, not plug and play.
Old Feb 7, 2005 | 07:55 AM
Dave2112's Avatar
Thats great..So worst case, its still do-able.. I was worried that it wouldn't work, no matter what.
Thank you
Old Feb 8, 2005 | 01:47 PM
UGAd13's Avatar
Really? That's F'ing awesome... Don't be a douchebag and repond with useless crap like that.
Old Feb 8, 2005 | 02:03 PM
maxspeed96CT's Avatar
The original VQ...
i thought it was at the wheels???
you got a dyno sheet!!!
Old Feb 8, 2005 | 04:52 PM
ronin22357's Avatar
i dont like the sound of it. i have the Hella supertones and they sound way better!
Old Feb 9, 2005 | 10:51 PM
mchne's Avatar
stock 4th gen horn is obnoxious.
I enjoy blaring it in even more obnoxious long island rush hour traffic.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
