Speedometer
Old May 5, 2001 | 12:07 PM
maxbob
My Speedometer is reading too slow I got a ticket the other day and now I have no clue what speed I am going. How can I fix the seedometer?
Old May 5, 2001 | 12:21 PM
mzmtg's Avatar
Minister of Silly Walks
How far off? If it's just a few percent (like 5%) it's probably just tire size issues. Even if you're running stock tires, as they wear they can affect the speedo. But, since it's reading low, that means that your tires would be bigger around than stock. If it's a big difference (like 15%) I have no idea...sorry.
Old May 5, 2001 | 12:33 PM
maxbob
No, its pretty bad
It reads pretty slow. I dont know exactly how wrong it is, but its more then 5%.
Old May 5, 2001 | 12:38 PM
bert's Avatar
The easiest way it to take a ride on cruise control and measure the time between mile markers. Obviously it's more accurate the further you go, but 10 miles would be fine. I built a grid for seconds per 1 kilometer. I will build it up for seconds per mile. With that you go take a run and time it. then you will know when your spedo reads XXX you are going YYY. (note that I am not telling you to do that run at over 3 digits on your spedo!)
Here is a link to a minutes/mile grid. Should be simple enough to figure out.
http://www.rallyracingnews.com/manuals/z770.html#20
If you need the KM one let me know I will fire off my Palm.
mzmtg's Avatar
Hmmm, if you have manual, check the vehicle speed sensor and all its connections, from the sensor, through the ECU all the way to the guage itself.
Old May 5, 2001 | 12:44 PM
maxbob
well i was hoping
That i can get my speedometer fixed and also get my ticket reduced. My speedo really is broken, but if its going to be too expensive to fix, i still want to try to get out of my ticket based on my inaccurate speedo.
Big Bob
Old May 5, 2001 | 02:34 PM
mzmtg's Avatar
Re: well i was hoping
Big Bob
Hmmm, before your court date, see if you can get a friendly officer to help you out. See if you can get him to clock you while you drive some pre-determined speed according to your speedo. Then if he's really nice, he'll testify that your speedo is broken. You wont need proof of a fix to get out of the ticket. Having a broken speedo isnt illegal, just the resultant speeding...
Old May 6, 2001 | 12:21 PM
nforg's Avatar
5%????? I know BMW's out of the factory come with a 10% over-estimate on their speedo, so if it says your going 150mph in a bimmer, your really only going 135mph.....
I assumed maxima just came with a 1% error, or something real small; although now that I say that I doubt they reconfigure the gle/gxe & the se's because there is a 1 inch tire difference at least.... hmmmm ....
BTW how fast did you think you were going, and how fast did the radar clock you??
Just so you know, in a lot of states you have the right to ask to see the radar to make sure he wasn't just lying (you probably should have done this), plus, how did the cop scan you? I mean was he driving in the opposite direction and he clocked you? I ask this because let's say there was a big van or truck coming up behind you going 80mph and you were going 40mph, the cop can clock you and it would read 60mph because it would be taking the van's and your's and splitting it....
-Nate
MR2 T'd
Jul 9, 2021 05:06 AM
jchronis2552
Sep 21, 2015 05:52 AM
Djsmaxima
Sep 14, 2015 11:58 PM
Jigaa
Jan 3, 2001 01:29 PM
